Installing A Closet Bar On An Angled Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-28-2010, 02:00 PM   #1
I am installing a closet bar in a bedroom closet. Because the bedroom is part of a finished attic, one of the walls of the closet is actually a sloped ceiling. Do they make mounting brackets for cloths bars that can mount on sloped surfaces? Seems like such a simple thing, but I cannot for the life of me find any such product.
I've also found a couple other descriptions of my problem that tell you to mount the bracket on the back wall of the closet, but do not go into detail how or why, as if it were obvious. Frustrating. Can anyone help?
This is a cross-post from the carpentry forum. Wasn't sure where to put it.
--only one thread on a subject - Thanks
Nathan0115 is offline   Reply With Quote
Old 06-28-2010, 02:50 PM   #2
the Musigician
DangerMouse's Avatar
This is how I'd go about it.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
Nathan0115 (06-28-2010)
Old 06-28-2010, 03:02 PM   #3
Ah, why didn't I think of that! Thanks so much!
Why did you include washers around the nails?
Old 06-28-2010, 04:15 PM   #4
the Musigician
I wouldn't use nails. Pre-drill holes in the block, use wood glue and SCREW to the upper piece, not nail.
Washers hold the block stronger than just screws/lag screws.
DM
Old 06-28-2010, 04:35 PM   #5
Newbie Bill
Rewards Points: 522
Yeah, remember just how much weight will be hangin off that thing. I'd want to make double sure the block doesnt get ripped out by hopefully finding a stud.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 06-28-2010, 04:43 PM   #6
Thanks so much! I appreciate it.
Old 06-28-2010, 04:53 PM   #7
the Musigician
The red was intended to depict a rafter, of course.
No way I'd trust that much weight to anything but! Po)
DM
Old 06-28-2010, 05:00 PM   #8
DM
Yeah, I just got done hanging the drywall in the closet. I have no desire to tear it down with a bar
Old 06-28-2010, 05:07 PM   #9
the Musigician
Good!, as long as you know where your studs are, yer good to go!
DM
Old 06-28-2010, 07:42 PM   #10
Rewards Points: 5,336
Instead of using the end connectors supplied with the bar, make your own from a piece of wood. Drill an angled hole that matches the angle of the wall. Install the plate with the proper fasters, based on expected weight load.
Ron
Old 06-28-2010, 08:31 PM   #11
If the studs are in the wrong position, you could use a beveled piece of wood to bridge across the studs.
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Removing Closet / Building Wall beespost Building & Construction 1 10-23-2009 05:15 PM
Installing New Wires In Wall? madcitysw Electrical 5 01-14-2008 08:08 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Help Me.....installing Wall Safe shaw Carpentry 7 10-01-2006 04:50 PM
