Installing Brick/stone House Number - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-17-2010, 12:32 PM   #1
Rewards Points: 93
Installing brick/stone house number
To install the brick/stone house number on brick wall above the garage door.
If i cut out the bricks enough to install this brick house number, would it affect the integrity/strength of the brick wall?
Thanks in advance.
quincy is offline   Reply With Quote
Old 11-17-2010, 12:41 PM   #2
Rewards Points: 5,336
Are you carving these into the side of the house?
How deep?
Why can't you mount them on the surface?
Ron
Old 11-17-2010, 03:48 PM   #3
Rewards Points: 93
Ron,
The house number will be carv into the flat surface cement block which have the same thickness as the brick, normally the brick layer will put it in when laying the brick wall,
If install after the wall is up, the bricks have to remove to make room for this cement block, plan to drill the bricks with the hammer drill then chisel then out, afraid to affect the adjacent bricks.
Old 11-17-2010, 04:19 PM   #4
Originally Posted by quincy View Post
Ron,
You want to use a grinder, not a hammer drill. Grinders will not cause vibrational trauma to the surrounding masonary.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
quincy (11-17-2010)
Old 11-17-2010, 04:21 PM   #5
concretemasonry's Avatar
Rewards Points: 2,640
Your description is a little confusing.
What is the basic wall construction? - full brick veneer over wood frame or concrete block or solid brick?
Brick is normally a veneer that has no structural value.
Is this new or existing construction?
Dick
concretemasonry is offline   Reply With Quote
Old 11-17-2010, 09:07 PM   #6
Rewards Points: 93
Hi Dick,
It is a brick veneer over an I beam above the garage door opening.
The house is 6 months old
Old 11-19-2010, 04:54 AM   #7
Rewards Points: 4,794
ronnie is 1 of the few knowing the difference between masonary & masonry well done, hiram ! ! !
Installing ceiling fan in old house wgoode77 Electrical 2 07-15-2010 09:35 AM
Installing a new panelboard in my house Gabriel24 Electrical 18 01-08-2010 05:01 AM
Foam Board on exterior of above grade house Sheldon General DIY Discussions 6 12-08-2009 04:05 PM
Installing new tub in a very old house MelBrown7 Plumbing 1 03-31-2009 05:31 PM
installing heating unit for a flat roof house gcampbell29 HVAC 6 02-23-2009 06:34 AM
