Installing Basement Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-24-2008, 05:19 PM   #1
installing basement windows
My basement windows are new, but currently only help in by some cedar shims.
What's the proper way to install these? They look as if they were meant not to be screwed to the block, so what sort of adhesive holds them in place?
Some of the gaps are quite big, you could probably stick a pencil in there.
john442 is offline   Reply With Quote
Old 03-24-2008, 05:51 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
My first question is: Who installed them? If you paid someone to install them, and that is what you got...then that's another story.
If your a midway thru your own installation of them, then we forgive you.
Generally, the windows are either:
1.) Ordered custom sized to fit the space, and installed snuggly, using adhesives.
OR
2.) The space is framed in with Pressure Treated Lumber to accomodate a standard size (or common sized) basement window.
In your situation: I don't know how large the gaps are. You may be able to fill them with non-expanding foam (for windows and doors). Then install (using caulking/adhesive) some kind of vinyl trim to cover the foam filled gap.
As far as fastening: in your situation, you have concrete block. I would suggest drilling the block with a tapcon masonry bit, and using an appropriate tapcon masonry screw. Before inserting the screw, inject (shoot) some masonry epoxy into the screw hole. On the bottom of the windows, you may want to use a good sealant to: seal and also to act as a "glue", to hold the window in place.
I am basing this advice on what you have described.
Good Luck.
- Build Well -
Old 03-24-2008, 07:38 PM   #3
welllll, my bro-in-law was doing some general work for me, "pro bono" and we all know how that goes. anyways
tapcons should do it, I just didn't see holes, I'll just have to drill some of my own. Thanks.
Old 03-24-2008, 08:50 PM   #4
BuilderRemodeler
Stop or trim molding
If over 1/8" needs to be filled after caulking or using expandable foam a piece of stop or trim molding can be added to cover this gap if the window is not sized correctly for the opening. Going with the Plastic or vinyl trim material may be a wise choice.
The Trim can be caulked into place with temp spacers cut between the moldings until the caulk is dry if there is not a wooden frame built around the window.
BuilderRemodeler
40 pages of useful Home Remodeling Charts, Home Addition Guidelines, Home Painting Tips, How to Determine a Deck Size and Build Your Deck Online! www.BrandsConstruction.com
www.HomePlansForFree.com One Story Ranch Detailed Free Home Plans
darylbrands is offline   Reply With Quote
Insulating basement windows Keyo77 General DIY Discussions 3 01-06-2008 06:33 PM
Novice question: Installing windows in wood sided home...(pic) Dr. Jim Building & Construction 5 07-06-2007 06:33 PM
Installing Windows after Drywall??? jeepwillies Building & Construction 9 11-22-2006 10:30 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
