Old 10-02-2007, 04:19 PM   #1
Installing an Anderson sash, without frame
Anderson replaced a couple of my casement windows under warranty (failed seals - a little cloudy), and I'd like to put one of the old sashes in the shed I'm building to add a little light. Can someone please suggest a good way to attach this sash, and weatherproof it a bit?
I've removed the hardware from the sash, so it's just a pane with a vinyl clad frame around it. The outermost part of the frame is a 1/2" wide flange with weatherstrip on it (where it used to seat against the frame when cranked closed.) I figured I could seat that weatherseal against the sheathing on the outside of the building, then butt some trim up to it, and put flashing above the top trim, and above the sill trim.
I think I'd hold it in by screwing some metal clips to the inside part of the vinyl clad frame, and screwing those to the 2x4s on either side of the rough opening.
Hows that sound? Any better advice on weatherizing it? It's an unheated shed, so it's not super critical that its perfectly weathertight, but I'd like it to keep water out, and away from the framing/sheathing.
NateHanson is offline   Reply With Quote
Old 10-02-2007, 07:57 PM   #2
Eibwen
I think I'd make up a couple of frames and router em so the sash can clamp in between em. then just screw it to the wall
Sammy is offline   Reply With Quote
Old 10-03-2007, 09:02 AM   #3
Not sure I understand Sammy. This isn't a double hung sash, it's a casement.
Old 10-03-2007, 06:28 PM   #4
Build a frame out of composite wood. Make sure the bottom slopes away from the structure and projects out past the siding. Install a perimeter of exterior stops the window can lean against and after the sash is installed apply a set of interior stops so the sash stays put. Trim out the exterior so it's weather tight.
Ron
Problem installing entry door Jemo Building & Construction 13 11-14-2010 12:31 PM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 06:29 PM
(urgent!) Covering/repairing damage on wooden door frame? Photinus General Discussion 2 07-19-2006 08:25 PM
Warning: Do NOT use "Duck Seal" by Anderson muenchk Flooring 9 07-19-2006 12:14 AM
mirror frame jdwdwd Carpentry 3 03-31-2005 10:34 PM
