Old 11-24-2011, 11:15 AM   #1
Installing 48" wide unfaced r19 in a pole shed
I am trying to figure out how to keep my insulation from falling down. I am installing this in a pole shed. The poles are 8' center. The insulation is 48" wide. The height is 18'. How can i install 2 sections from bottom to top without it falling down or settling over the years. It is unfaced so there is no where to staple it fast to the wood?
WBROUSE is offline   Reply With Quote
Old 11-24-2011, 01:10 PM   #2
What sort of wall material are you putting over the insulation?
For smaller width insulation I've use the wire rods to hold the standard 14 1/2" batts in place. You might try threading the rods through the insulation to sort of hang it in place until the wall covering goes up. Or you could cut the height in half(thirds) be installing a framing block to reduce the mass hanging the full 18 feet.
Or you could do both if needed.
Ron
B. Franklin 1759
Old 12-06-2011, 01:09 PM   #3
I am going to run 2x4 perlons from post to post and then cover it with white vertical metal. Before I put the perlon on I am going to sheet it with plastic for a vapor barier.
Old 12-06-2011, 02:54 PM   #4
SteelToes's Avatar
I've seen a similar application on a commercial project where they used some sort of fiberglass mesh netting in between steel columns to keep the batt insulation in place .
I don't know the name of the product but i'm sure its priced "commercially"
You mentioned you're going to install corrugated panels on the inside.I would just double up on horizontal furring strips and use 'em instead to keep the insulation in place.
SteelToes is offline   Reply With Quote
Old 12-10-2011, 06:46 PM   #5
Thumbs up
I actually found a good way to do this. I pounded in metal wire staples about 2 1/2" back on each side of the main pole. I put them every 2 feet staggering them from the left side to the right side. Then I cut the insulation to 10' high sections and put them in. holding them up with nylon string that you use to pull wire thru conduit pulling it tight as I go. It works super.
Thanks For all the responses
Old 12-11-2011, 11:05 AM   #6
Another option would have been for you to use insulation mounting pins. These pins are constructed using #10 galvanized wire welded to a perforated base plate (1 1/2" square). A dab of construction adhesive is placed on the wall and the perforated plate is pressed into the dab.
24 hours later, the insulaion is hung over the pins and held in place with a spring nut that is slid over the wire.
The extra wire projecting beyond the spring nut is turned back, as the sharp end of the wire is dangerous.
Old 12-13-2011, 01:56 PM   #7
Where do you get these type of mounting brackets at?
Old 12-13-2011, 11:16 PM   #8
I bought mine at a construction supply business! They are used in HVAC trade extensively. Call a HVAC business and they will be able to name a supplier.
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General Discussion 32 10-23-2012 09:54 PM
Installing a 60A sub-panel in detached shed (distance 80ft) Ebeameup Electrical 8 06-06-2010 04:17 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 12:09 PM
Installing Service In Shed. bobo60 Electrical 61 02-07-2009 12:46 AM
