Installing 200 X 63 (mm) Lvl Beams - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 04:39 AM   #1
installing 200 x 63 (mm) lvl beams
Hi i am having to re structure my roof. It was a flat roof and i am now converting to the traditional gable type with properly engineered trusses.
The plans call for 200 x 63 mm lvl to be installed around the perimeter.Thus tying the roof structure. my question is which method would be best for mounting beams to the wall framing top to avoid twist. I have had one builder tell me to use hoop ties ? i think a metal U shape that goes over and down each side is this o.k. not sure what spacing .Would appreciate any help
Thanks tim
timmo is offline   Reply With Quote
Old 05-02-2011, 08:21 AM   #2
Rewards Points: 5,336
I'd contact the beam manufacturer for guidance or the engineer who spec'ed the structure.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
timmo (05-02-2011)
Faux Wood Beams JudyFaye Building & Construction 2 06-08-2012 05:05 PM
Connecting Beams And Post JoeLena Building & Construction 5 01-01-2011 05:32 PM
Wiring on exposed wood beams - Ontario Canada djgap Electrical 5 09-29-2010 01:41 PM
hanging weight off of tji beams?? summer76 Building & Construction 2 04-14-2009 03:00 AM
