Old 10-29-2012, 03:31 PM   #1
installation of siding on a house
The contractor used pieces of cardboard to even out surface and then installed siding over it. Does that meet Chicago code?
Ms H is offline   Reply With Quote
Old 10-29-2012, 03:40 PM   #2
Would not meet code any place!
Should have use fan fold insulation instead in most cases.
Old 10-29-2012, 04:26 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
cardboard is only ok for interior purposes when a stud needs to be furred out by 1/8 - 3/16 for drywall to lay flat.. for exterior you have to use something that is rot resistant as joe mentioned.. .. when were installing siding that gets a rain screen detail we use cedar shims behind the strapping and run a long level across the strapping to create a true surface
woodworkbykirk is offline   Reply With Quote
Old 10-29-2012, 04:29 PM   #4
Noooo!
packer_rich is offline   Reply With Quote
Old 10-30-2012, 07:58 AM   #5
Thank you for the replys. Now what do I do have them remove the siding and re-do it?
Old 10-30-2012, 09:25 AM   #6
Yeeeeees!
Attaching wood fence to house TheCowGod Building & Construction 5 04-13-2012 04:57 PM
Large section of siding removed - use house wrap before re-siding? nelsonC Building & Construction 3 06-07-2011 09:06 AM
How to add a dividing fence to chain link fence and house with siding catburke Building & Construction 0 09-20-2010 02:39 PM
New vinyl windows, house has siding mdalli Building & Construction 7 09-19-2010 01:48 PM
House trim has rotted my siding ovahimba Remodeling 5 01-22-2010 02:58 PM
