Install Vapor Barrier Or Not Install...Advice Please.. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-16-2010, 06:07 PM   #1
Demolition Mode
Rewards Points: 129
Send a message via Yahoo to HandyDave
Question
Install Vapor Barrier or Not Install...Advice Please..
Well I made my goal today to get the old floor torn up on the Chicken Coop, get some pics and post for advice before i put down a vapor barrier.. (or maybe not)
The Pics show the original floor and rotted joist and particle board flooring.
Am I correct to lay down 6 mil plastic over the dirt or is this not necessary in this application? I am not sure what I will do with the building when I get done with it, a cabin, garden shed, perhaps? Should I put rigid foam board in between the joist???
I will be using treated lumber for the floor joist on top of the vapor barrier unless i get advice not to use treated lumber.
Any suggestions on proceeding with Vapor Barrier and insulation will be greatly appreciated.
Install Vapor Barrier or Not Install...Advice Please..-vb1.jpg   Install Vapor Barrier or Not Install...Advice Please..-vb2.jpg   Install Vapor Barrier or Not Install...Advice Please..-vb3.jpg
HandyDave is offline   Reply With Quote
Old 02-16-2010, 06:20 PM   #2
jlhaslip's Avatar
Rewards Points: 2,820
I would dig out under those joists and block them up using Pressure Treated lumber for the blocks, and, yes, use 6 mil under the concrete as well as against the joists. No wood to concrete without a membrane.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 02-16-2010, 06:29 PM   #3
Demolition Mode
Rewards Points: 129
Confused?
you said "use 6 mil under the concrete as well as against the joists. No wood to concrete without a membrane. "
Concrete? Am I missing something here? I simply plan on laying the vapor barrier down, then the treated floor joist .
Old 02-17-2010, 07:42 AM   #4
ccarlisle's Avatar
Moisture will rise through the flooring and continue to create a humid interior unless you put down a vapour barrier first.
If you had particle board there, that's probably the reasoon it disintegrated (it doesn't like humidity) and I'd look for another subfloor material.
Then you can do what you want with the flooring - insulate it if you will be heating, or just want to walk around in bare feet - Some people might say use treated lumber, some no way. I would, for the joists. Cover that with OSB or plywood...
But I'd also have a look at the walls, there seems to be rain coming in...? wrap that in Tyvek or something to keep the bulk of the water out...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 02-17-2010, 08:16 PM   #5
Demolition Mode
Rewards Points: 129
Yup....Ill be laying a vapor barrier down, sealing it good, using treated floor joist and 3/4 inch plywood for the floor. I was wondering about the staining on the walls... I do plan on residing the building and will definatly be wrapping it in tyvek. Ill attach some pics when i get the joist in.
Tags
chicken coop , outbuilding , vapor barrier
Anyone install a tin/copper style ceiling? flashme18 Remodeling 7 07-19-2009 07:56 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
Can I install 3/4" HW on top of the rolled floor membrane there now? davevarga Flooring 3 03-09-2008 10:16 PM
