Install Replacement Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-13-2011, 05:32 PM   #1
Install replacement window
cost to install a replacement casement window 7' 7" wide X 4' 4" tall aluminum clad - opening exists.
DANNY T is offline   Reply With Quote
Old 11-13-2011, 05:37 PM   #2
Framing Contractor
Impossible to answer. You HAVE to call contractors in YOUR area to give you an estimate.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-13-2011, 06:32 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,326
exactly, what brand do you want. do you want double glazed? triple glazed.. you need to give more info.. and as joe mentioned your region. labour rates and material prices vary from region to region and contractor to contractor
woodworkbykirk is offline   Reply With Quote
Old 11-14-2011, 03:05 PM   #4
About $250 for labor - that the minimum charge most of the company's have. If you will have 10 windows that will be cheaper per window.
marins is offline   Reply With Quote
Old replacement window jsfoltz Windows and Doors 1 08-26-2011 07:27 PM
Replacement window question on install... tidal9 Carpentry 1 08-16-2011 10:18 PM
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 02:05 PM
Window Install Question Tom5151 Building & Construction 1 09-29-2009 09:34 AM
Window Install? sod Building & Construction 3 10-26-2008 07:02 AM
