Old 05-27-2010, 11:40 PM   #1
Question
Install Partition Stud Track over Laminate Floor
I live in a condo on the 7th floor. The condo is concrete inside and outside including floor. The existing floor finish is laminate floor. I want to build a partition without removing the laminate floor, but it will cost a lot money and work to replace the floor. The Homedepot staff told me the laminate floor "float" on the slab without being nailed.
If I use a gun shooting nails to mount the metal or wood bottom track, will the laminate floor split?
Could someone please give me some ideas if the existing floor matters when I use a screw shooting gun? (I prefer gun as it is faster and less noisy than hammer drill)
Thanks in advance!
Andy21 is offline   Reply With Quote
Old 05-27-2010, 11:52 PM   #2
no the laminate will not split, but your flooe is floating if you nail through it the floor will eventually buckle because it cant exand or contract. you have to cut the flooring out were your wall plates will be and leave at least a 1/2" gap between floor and plates
mark2007 is offline   Reply With Quote
Old 05-28-2010, 07:41 AM   #3
Of course, the Home Depot guy doesn't know if your laminate floor is floating or glued down.
RoyalAcresRod is offline   Reply With Quote
Old 05-28-2010, 12:11 PM   #4
If the floor is floating you don't want to secure the wall plate to it as it will eliminate the floor's ability to float (expand and contract with temperature, humidity, etc.). If the floor is glued then you can secure the wall plate through it.
If floating, you'll need to cut out a section to accommodate the wall plate - leaving 1/4"-3/8" gap between the floor and the wall. Baseboard will cover this gap. Even if not floating, I would probably cut out a section to accommodate the wall plate - not a big deal to do. Seems like just the better way to do it.
Old 08-13-2010, 12:28 AM   #5
Thanks guys!!
There is a kind of double-sided foam tape, with which the aluminum installer can tape the bottom piece to the floor finish as long as the floor finish is smooth. 3M also produce some tape for this purpose. My partition is going to be 88"W x 7'7"H, not too heavy. What do you think if I tape the bottom track rather than screw it through the laminate floor to the slab or cut the floor?
Old 05-27-2011, 04:31 PM   #6
is this partition going to be attatched to anything on either end like another wall?
Old 06-24-2011, 01:37 PM   #7
Thanks DannyT. I have done it by cutting out a slot over the engineering flooring. But there is a bullhead over it, so I think I could use the double sided foam type which a lot of office divider installers use. But it is fairly expensive.
Old 06-24-2011, 03:00 PM   #8
Andy, you need to focus.
Is the floor floating or is it glued down?
If it's floating, cut out where the wall will be and secure the bottom plate of the steel stud directly to the concrete.
If it's a glue down floor, attach the bottom plate through the floor into the concrete.
What is a "bullhead"?
Ron
B. Franklin 1759
Installing Laminate Flooring over Wood Laminate Floor bantammom Flooring 7 05-27-2011 04:34 PM
scratches on laminate floor tarheelblue Flooring 1 03-17-2010 08:41 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Horizon Laminate Floor from China Kelvestto Flooring 3 09-20-2006 12:19 AM
