Install Integrity Windows Over Asphalt Felt Or Other Rough Opening Treatments? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-05-2009, 09:27 AM   #1
Rewards Points: 45
Install Integrity windows over asphalt felt or other rough opening treatments?
After reading the instructions on the Integrity windows it lists a procedure for installation over asphalt felt. Is is best practice to this is even with having to make 90deg bends in the felt to allow it into the rough opening (won't it crack)? How about getting some wide, flexible PVC and using that in place of the asphalt felt to line the rough opening before applying sealant, nailing fin then flashing?
kooshball is offline   Reply With Quote
Old 12-05-2009, 09:43 AM   #2
Remodeling Contractor
The felt wraps into the window frame. The nailing fins get caulked and nailed. Then apply window flashing over the fins and over the felt. At the top the flashing tape laps the sides (which lap over the bottom). Tuck the top flashing tape under the building's vapor barrier. The idea is that everything from above is over the bottom so water continues to shed.
Old 12-05-2009, 09:51 AM   #3
Rewards Points: 45
I have not had good experience getting strong adhesion to the felt paper with Dynaflex 230 and the folks at OSI say that their Quad product won't stick either. My though was that by substituting PVC for felt at the rough opening I would get good adhesion to the substrate. Any thoughts on sealants that will stick to the felt and not have negative impact on the PVC nailing fin?
Thanks.
Old 12-05-2009, 10:01 AM   #4
caulking is used only for stopping air infiltration, not for "gluing" the window to the felt or anything else. The nailing flange is used to fasten the window. The flashing is used to waterproof the window.
Old 12-05-2009, 09:18 PM   #5
Rewards Points: 45
Makes sense. I guess as long as I get a good wet-out when I set the window in place I will be fine after the flashing tape is applied.
Thanks.
Old 12-05-2009, 09:42 PM   #6
Registered User
Rewards Points: 5,524
Don't forget the sticky flexible tape on the sill and the head flashing above, as per instructions: http://www.integritywindows.com/down...DocumentID=787 From: http://www.integritywindows.com/?pag...n_Instructions If that is your window....
Be safe, Gary
Old 12-06-2009, 07:34 AM   #7
Rewards Points: 45
GBR, that is my window; I am planning to follow the instructions exactly.
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Rough Opening issues for interior Pre-hung door get2bill Carpentry 3 04-04-2009 07:27 AM
Cost to Install 2 Transom Window's dcd22 Building & Construction 3 07-25-2007 07:52 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
