Install A Garage Door Mail Slot - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-29-2007, 05:24 PM   #1
Install a garage door mail slot
Hi there,
Does anyone know where I can find instructions on installing a garage door mail slot? I am a bit of a noob so I'm going to need details such as, how to cut through the metal garage door, what type of mail slot to buy etc.
Any help is appriciated.
Thanks in advance.
fesymny is offline   Reply With Quote
Old 11-29-2007, 05:35 PM   #2
s0lidgr0und's Avatar
I'm not sure they make them specifically for garage doors. That's sort of strange. I'd probably see if there was a jigsaw blade made for sheet metal. Draw the lines specified in the installation directions, take a drill to the four corners of the drawing, and then use the jigsaw to trace the lines from corner to corner. Then I'd assume that the installation would follow the regular instructions from that point on.
s0lidgr0und is offline   Reply With Quote
Old 11-29-2007, 06:15 PM   #3
Eibwen
Make sure to check postal regulations before you begin... I remember once a mail slot that was cut too low in a door. Mail carrier walked by and said he didnt have to bend over that far carrying a sack of mail to put it in the slot.
Sammy is offline   Reply With Quote
Old 11-29-2007, 07:59 PM   #4
Damn union employees.
double car garage slightly uneven... mcvane Building & Construction 6 11-25-2007 08:41 AM
Useless Ridge Vent? itwerx2 Roofing/Siding 22 10-22-2007 09:57 PM
Crazy Garage Extension, Building over blacktop?!?! commissure General DIY Discussions 4 09-13-2007 11:09 AM
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 10:38 PM
