Install Door Now Or Later? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-13-2010, 06:44 PM   #1
Install Door Now or Later?
Due to some water damage I had to replace the floor (everything down to the joists) in my utility room.
I have fastened the new 3/4" T&G plywood subfloor to the joists in my utility room. I plan on laying down 1/2" plywood as my underlayment for the vinyl.
There was an exterior door in the utility room that leads into the garage; I had to remove it in order to remove all of the subfloor. Should I put the new door in now? or wait until after the underlayment and vinyl have been installed? It is considered an exterior door, so there will be a threshold.
I am assuming that it will be easier and look "cleaner" if I install the door after I am completely finished with the floor... but I do not know too much about construction so any advice would be appreciated.
Thanks,
Monkey
monkeystomach is offline   Reply With Quote
Old 05-13-2010, 06:54 PM   #2
DIY staff
Rewards Points: 7,174
You will get better clearance for a rug if you wait till the 1/2 inch ply goes in--I'd wait--Nice to have a rug at that door.-
Check the door opening with a level. If the door needs a lot of shimming --you might want to install it before the 1/2 inch ply--That would hide the shims.---Mike---
Old 05-13-2010, 07:12 PM   #3
do it last, a piece of quarter round at the sill will cover shims
The older I get the better I was
The Following User Says Thank You to tpolk For This Useful Post:
oh'mike (05-13-2010)
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 02:29 PM
Fiberock install STUPID Flooring 5 10-16-2007 06:29 PM
