#1 |
Install Cabinets directly above Tongue & Groove?
Our kitchen flooded and the plywood subfloor had to be removed.
All that remains is 2x8 fir tongue and groove boards resting on joists. We can see the dirt under the house through some gaps and knots big enough to put your fist through (old 1965 construction). Our contractor is installing the cabinets above the tongue and groove with just a few slats around the edges. To me this seems strange. No subfloor, no moisture barrier, and some gaps between the 2x8s big enough for a critter to move in under each cabinet. Should we ignore this or insist that a subfloor (or something like a moisture barrier?) be installed between the tongue and groove and the cabinets? Thanks. Our contractor is 90% done installing our kitchen base cabinets directly over tongue and groove (using a few strips of plywood around the edges only). We can see the dirt under the house between the T & G boards and there are numerous gaps and 2" holes in the boards where knots came out), so I'm concerned that there should be some type of sub floor and/or moisture barrier. Is it worth having him tear them out and put in a sub floor? 2 threads on same issue merged |
#2 |
You talking to me?
what is he attaching the T&G to if there is no subfloor under only the cabinets?
If there is a subfloor in the rest of the room, that would mean the T&G is up off the joists the thickness of the subfloor. based on what you have, yes, you need a subfloor. What you have now will allow insects and animals to come into your cabinets. |
#3 |
definitely needs new subfloor, and that crawl space should be covered with plastic to keep down moisture.
#4 | |
Install Cabinets directly above Tongue & Groove?Quote:
#5 |
Remodeler
If you have a crawl space under the kitchen, you definitely need to have the contractor fill the "gaps" under the cabinets. You most likely aren't going to get him to remove the cabinets and reinstall, but rather fill from below.
#6 |
Thanks JCarsten. Are you thinking that expandable foam or something similar?
#7 |
Remodeler
That's what I would use.
If you are seeing "dirt" in your crawl space, you might want to look into your local building code (or ask your local inspector) about a vapor barrier. States most likely vary on code, but in MN we are required to put a vapor barrier over ground cover in a crawl space. |
#8 | |
Given all that, and the work they've done so far seems to be of good quality, and that they are doing this for a very fair price, it seemed compelling enough to not stop everything, tear out the cabinets, cancel granite installers, tile installers etc, and let them continue. |
#9 | ||||||||
You talking to me?
the thing the guy fails to mention is that a subfloor is usually under another layer of flooring. As such, the knotholes and a not quite as tight fit isn't as important as it is when the subfloor is the only floor. The fact it is the only floor, the integrity of that floor is much more important. Quote:
I would suggest speaking directly with your local building department and getting their take on the situation. If it passes code, the it is what it is and you demanding any additional work will come as additional cost. If it doesn't pass muster, then the guy can fix the thing. Either way, you can have some peace of mind knowing what the building department requires. |
| The Following User Says Thank You to nap For This Useful Post: | caezaar (07-06-2010) |
#10 |
Moderator
"Our kitchen flooded and the plywood subfloor had to be removed. " -------- (underlayment)
"All that remains is 2x8 fir tongue and groove boards resting on joists." -------- (sub-floor) http://bct.nrc.umass.edu/index.php/p...ient-flooring/ http://www.apawood.org/pablog/index....-Floor-Systems The 1x's ALWAYS get a underlayment between it and finish cabinets: Page #150-152: http://books.google.com/books?id=bwt...page&q&f=false At the very least, install builder's paper...... If the crawl space is vented, expect some warpage in the cabinet drawers and doors next Winter. (And bugs, spiders, mites in the house). Usually, finish floor material is installed on the underlayment right next to the cabinets, unless tile. Ask your Fire Marshal or B.D. as it has to be fire-stopped (no gaps) between floor and crawlspace. Page 4- fire-blocking: http://www.codecheck.com/cc/images/CC5thEdSample.pdf Be safe, Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#11 |
Putting cabinets over that sort base is idiotic. It subjects a finished wood product to excessive moisture. Any competent contractor would have discussed the crawlspace issue long before he started the job. Vapor barriers, insulation and a plywood layer should have been discussed, based on your location.
Ron |
#12 |
Moderator
#13 | |
You talking to me?
#14 |
Moderator
Been there, done that. Feel older than before..........lol
Be safe, Gary
| Display Modes | |
| Tongue and Groove Ceiling install....questions... | Dr. Jim | Remodeling | 9 | 04-08-2012 01:14 PM |
| Laminate flooring install questions | wilderstyle | Flooring | 2 | 02-19-2009 04:45 PM |
| Framework to space cabinets from wall | red3908v | Building & Construction | 6 | 08-02-2008 05:45 PM |
| How are the premade HD and Lowes Cabinets? | twilightcall | Carpentry | 10 | 05-25-2008 11:23 AM |
| Excessive shimming to keep wall cabinets flush with one another? | alexz | Carpentry | 10 | 12-22-2007 08:48 PM |
