Install (attic) Door To Access Space Above Garage ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-03-2013, 10:31 AM   #1
Rewards Points: 85
Install (attic) door to access space above garage ?
We have a bedroom above the garage. There's a 32" clearance between the garage ceiling and the bottom of the floor joists of the bedroom floor.
This space has HVAC ducts and electrical wires. I'm currently running some wires and access to this space could be useful again in the future. I was thinking about installing an attic door to access that space.
I'm currently waiting for a response from the city to see if this would pass the local building code. But in the meantime, I was wondering if it's a good idea. I would need to seal and insulate the attic. Any pros and cons ?
Here a quick diagram to demonstrate the plan:
westbank is offline   Reply With Quote
Old 10-03-2013, 10:36 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,958
Anything to make it easier and safer is good...
Assuming they let you....I would highly suggest using the type of ladder that is telescoping....not the fold down type. The money difference is not worth the PIA the fold downs are...
While your at it...run yourself a GCI outlet and a light...on a timer......
Old 10-03-2013, 10:53 AM   #3
concretemasonry's Avatar
Rewards Points: 2,626
There may be some fire safety problems since it is a living area over a garage with an opening that may have to have a fire resistance rating. - Similar to the need for a rated door between and garage and a living area,
Dick
concretemasonry is online now   Reply With Quote
The Following 2 Users Say Thank You to concretemasonry For This Useful Post:
ddawg16 (10-03-2013), westbank (10-03-2013)
Old 10-03-2013, 10:59 AM   #4
cortell's Avatar
Rewards Points: 504
Curious. What's holding up the garage ceiling sheetrock? Joists or basic 2X4 soffit framing? Your diagram doesn't cover that important detail. I'm assuming the latter. If so, then that area was probably not designed to support a person. If you put an attic door there, then that invites someone to get up there and crawl around. Bad idea. But maybe I'm missing something.
cortell is offline   Reply With Quote
Old 10-03-2013, 11:09 AM   #5
Rewards Points: 85
Good point. I expect the city will probably ask for a fire rated & self closing access door.
Dick
Old 10-03-2013, 11:15 AM   #6
Rewards Points: 85
You're right. The sheetrock is supported by 2" x 4" framing (12' wide span / which has been nailed on the exterior walls 2" x 6" framing). It's strong enough to support one person but it will be complicated to crawl up there (insulation, HVAC pipes etc...). This access would be mainly intended to run electrical wires or potentially fix an HVAC/insulation issue.
Old 10-03-2013, 11:28 AM   #7
cortell's Avatar
Rewards Points: 504
Hm. I think that's highly debatable. It may appear so, and it may be holding up your weight, but that doesn't mean it was designed to support a person's weight and that means it may not reliably do so. If and when it doesn't, someone could get hurt.
Code is mostly about safety. My bet is that the city will say no, based on the hazard it creates. Now, if you wanted to create access doors at various points across that soffit, the city would probably not care about that. The access doors will not invite someone to climb up *into* the area, whereas attic doors definitely do. A subtle distinction but an important one, IMO. But, that's just my guess.
The Following User Says Thank You to cortell For This Useful Post:
Old 10-03-2013, 12:05 PM   #8
Rewards Points: 85
I totally agree with you. I'm just guessing that the framing can support one person but from an engineering standpoint, I could be wrong.
Installing one of two small fire rated access doors could be an option. This could be enough to run wires without the need to cut the drywall.
Thanks again. Much appreciated.
Tags
attic , door , garage
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Plywood around attic access kicken Carpentry 3 08-29-2011 01:03 AM
Insulation in Garage Attic ? SaDan Building & Construction 2 05-09-2010 05:44 AM
Insulating garage / adding attic Red Squirrel Building & Construction 4 04-19-2010 07:33 PM
