Old 07-13-2009, 11:08 PM   #1
Wire Chewer
Red Squirrel's Avatar
inside stair safety codes
I want to look into making my stairs less steep and pretty much remaking them. These lead to the basement, so doing this would give slightly less head room, but think I can manage to do it without it being too much of an issue.
I know there are certain code requirements such as the minimal head room, the size of lumber to use for the framing, how much of the wood must remain after making the triangle cuts etc...
Could someone tell me what are code/safety things I need to keep in mind while doing this job? Guessing this varies per region, I'm in Ontario, Canada.
Old 07-14-2009, 12:19 AM   #2
Moderator
This is your Country's Code Check book, I downloaded for free as you can also, if you stay out of that attic. It is the same one I paid $18 for 5 years ago. Pick your format: http://www.codecheck.com/cc/pg07_08building.html
Here is a good stair code: http://www.stairways.org/pdf/2006%20...C%20SCREEN.pdf
Be safe, G
Old 07-14-2009, 12:49 PM   #3
Wire Chewer
Thanks I'll keep those handy for when I tackle the project
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
Lighting for stair risers jweiner Electrical 2 04-06-2009 06:18 AM
Stair framing question stubborn1 Carpentry 6 01-19-2009 12:12 AM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 04:05 PM
Recessed pull-down attic stair BlueTheCow Carpentry 4 10-31-2007 06:54 AM
