Inside Dimensions Of Outside Corner Moulding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-10-2012, 05:04 PM   #1
inside dimensions of outside corner moulding
I am looking online at a Royal polymer trim which is 11/16" x 11/16". Royal calls it:
Outside Corner
6577
11/16 x 11/16
Colors: BW, CW
Home Depot calls it:
Royal Mouldings 8 ft. x 11/16 in. x 11/16 in. Polymer Outside Corner Moulding
I believe this is what I need, but I live quite a ways from a Home Depot, and will have to have them order it, and I need to know the inside dimensions as well as outside. I can't find it anywhere online. Can anyone of you help me?
Thanks!
Joni
joni41 is offline   Reply With Quote
Old 11-10-2012, 06:03 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,244
call a royal supplier not hd.. royal should be able to tell you
your going to get different codes from dealer to a store.. they have their own product codes
chances are though its either 3" or 5 "
woodworkbykirk is offline   Reply With Quote
Old 11-11-2012, 08:14 AM   #3
AHH, SPANS!!!
Rewards Points: 1,166
the only difference in the inner and outer dimensions is the thickness of the material which is 1/8" thick so if the outer dimension is 11/16" then the inner dimension will be either 1/8" less than 11/16 or if the inner dimension is 11/16" then the outer dimension will be 1/8" greater than 11/16. not to much size difference... chances are that the outer dimension is 3/4" and the inner is 11/16"
hand drive is offline   Reply With Quote
Glue coped inside corners of crown moulding? Klawman Carpentry 27 10-01-2013 04:43 PM
Crown Moulding - Inside corners. Moulding upside down? mb88 Carpentry 5 09-21-2012 04:37 PM
Inside corner Deck constructions handycuzofdad Building & Construction 0 06-04-2012 09:46 PM
Mating drywall to plaster on an inside corner acme54321 Drywall & Plaster 4 10-13-2010 11:09 PM
Left or right hand crown inside corner? Klawman Carpentry 9 01-08-2010 03:19 PM
