-   -   inside dimensions of outside corner moulding (http://www.diychatroom.com/f19/inside-dimensions-outside-corner-moulding-162864/)
joni41 11-10-2012 05:04 PM
I am looking online at a Royal polymer trim which is 11/16" x 11/16". Royal calls it:
Outside Corner
6577
11/16 x 11/16
Colors: BW, CW
Home Depot calls it:
Royal Mouldings 8 ft. x 11/16 in. x 11/16 in. Polymer Outside Corner Moulding
I believe this is what I need, but I live quite a ways from a Home Depot, and will have to have them order it, and I need to know the inside dimensions as well as outside. I can't find it anywhere online. Can anyone of you help me?
Thanks!
Joni
woodworkbykirk 11-10-2012 06:03 PM
call a royal supplier not hd.. royal should be able to tell you
your going to get different codes from dealer to a store.. they have their own product codes
chances are though its either 3" or 5 "
hand drive 11-11-2012 08:14 AM
the only difference in the inner and outer dimensions is the thickness of the material which is 1/8" thick so if the outer dimension is 11/16" then the inner dimension will be either 1/8" less than 11/16 or if the inner dimension is 11/16" then the outer dimension will be 1/8" greater than 11/16. not to much size difference... chances are that the outer dimension is 3/4" and the inner is 11/16"
