Inserting Hooks Or Loops Into Existing Mortar - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-21-2013, 11:07 PM   #1
Inserting hooks or eyes into existing mortar
I've got a net over my pond to keep animals and birds out but I need to install hooks or loops at ground level to attach the netting and keep it taught. After drilling the hole, what type or mortar or glue should I use to keep it permanently in place? I'd rather drill into mortar than stone.
Here is a pic of the area. I've got to install hooks or eyes at ground level for both ponds.
texmaster is offline   Reply With Quote
Old 03-22-2013, 04:53 AM   #2
Rewards Points: 4,656
any pool company can supply you w/lead shield'd anchors,,, these are normally hook points for bungees attached to pool covers,,, doubtful your mesh has strength of std pool covers but the lags/bungees will work
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 4 02-10-2010 10:27 AM
New Roof and Insulation over Existing Roof MitchellScott Roofing/Siding 1 05-03-2009 08:24 AM
Can I dye existing brick mortar? Foo by Tore General DIY Discussions 2 10-30-2008 07:03 PM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 11:16 AM
Mortar removal from salvaged brick. Rem8 Building & Construction 8 07-20-2008 07:05 AM
