Inground Pool Cement Deck/pad - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-26-2010, 10:50 PM   #1
Question
inground pool cement deck/pad
We're in the process of having an inground pool installed. We'd like a 4 ft cement deck around the pool. As a finished product it will look like a sidewalk around the pool. At present the pool is sitting waiting to be backfilled. Around the outside perimetre of the pool at the base there is cement. There are sonotubes around the pool, approximately every 5-6 ft. Once backfilled the sonotubes will be standing up vertical and will be cut to ground level. Apparently, then the sonotubes will be filled with cement which connects to the base cement around the outside base of the pool, and then the 'sidewalk' will be created around the pool. We've been told that after the concrete dries, they will sawcut lines through the 'sidewalk' across the top of each sonotube, and this will help with cracking / movement. The point of the sonotubes is for structural stability, and they are minimum 4 ft deep so as to be deeper than the frost line. Is this correct? I cannot find ANY codes regarding 'sidewalk' building in the Ontario Building Code.
newbie pool is offline   Reply With Quote
Old 06-26-2010, 10:57 PM   #2
Concrete & Masonry
Rewards Points: 526
Sounds typical to me. I take it this pool has some kind of steel walls? I've done a few just like this before, and the concrete is necessary to re-enforce the pool coping. Every part seems legit to me.
jomama45 is online now   Reply With Quote
Old 06-26-2010, 11:02 PM   #3
It does have steel sides......thanks for the reply. It's the part we haven't been able to monitor ourselves.
Anyone here have an inground pool? Any advice? Jeekinz Landscaping & Lawn Care 11 07-27-2016 09:38 AM
inground swimming pool pipes leak when pump running.. rgebhard Plumbing 4 06-26-2010 07:35 PM
cement pool deck... acrylic, epoxy or stain? vickipalma Painting 4 09-17-2009 02:09 PM
Inground Vinyl Pool Question intofire Landscaping & Lawn Care 0 09-11-2008 11:34 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
