Info On Building Half Walls? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-16-2009, 09:00 PM   #1
Info on building half walls?
This house was built in two sections and moved to current location. There is a partial wall between the dining and living area and I would like to build a half wall using this 5' section of wall so we can have more light in the living area. Would 5' make a crucial difference in a load bearing wall, if it is a load bearing wall and I plan on installing a header and 4x4 column.
Gmother is offline   Reply With Quote
Old 10-16-2009, 09:57 PM   #2
Civil Engineer
Rewards Points: 4,792
If I understand what you are saying, you would like to remove 5 feet of load bearing wall, and replace with a header and a 4x4 column. Any time you remove part of a load bearing wall, you need to have the header sized to carry the new load, similarly for the column. Sometimes you need an engineer to look at the loading and size the structural elements, in some cases the contractor does his own computations prior to pulling the permit. So in answer to your question, five feet can make a large load difference, and you need to design carefully.
Daniel Holzman is online now   Reply With Quote
Load Bearing Half Walls??? HoneyDo007 Building & Construction 5 10-04-2009 11:53 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
Basement half walls to full walls Basement Man Remodeling 11 03-29-2009 02:33 PM
Building a movable garden shed/greenhouse gardener Building & Construction 1 06-13-2008 04:47 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
