Old 11-06-2009, 06:47 PM   #1
Default Inexpensive way to section off unfinished basement?
We have an unfinished basement (concrete floor, no interior walls, exposed beams) and need to section off an area at the bottom of the stairs leading to the first floor to create a small 10' x 5' vestibule (reason: we want to put a litter box down there and don't want the cats exploring the rest of our filthy basement). The stairs run down an exterior wall, that wall intersects with the back wall so we would only need to enclose the other two sides to section this part off:
I'm ready to just go ahead and frame this thing out and throw up drywall and a door, but are there any other options we should consider? Take into account that this is likely temporary anyway; we have in mind finishing this space in the next 4-6 years, so whatever goes in here would just be torn out. No need for any insulation, sound deadening, etc. Just needs to be a cat barrier. And, yes, those suckers can jump high! If we do frame it out I am going to probably put in accordian doors or a large sliding door on the long side to make moving stuff from the basement to the 1st floor easier (with a standard door opening that turn would be a little tight for larger objects). Thanks!
eastie is offline   Reply With Quote
More On This Topic
Whether you have one dog or several, a place in your home that is exclusively a dog space can prove convenient and practical. A dog room offers play space, kenneling during the work day or at night and an indoor kennel when house activities are not dog... Read More »
In bi-level houses, transporting soiled laundry downstairs wastes considerable effort. A simple solution is to transform a closet into a laundry chute. There's no need to give up an entire closet; a small addition against one wall can be an effective... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. Some of the common things you want to watch for in framing, is to make sure that all of your walls are plum, level and square. This keeps everything... Read More »
Next area we are going to talk about is the stairs. Whenever I tell the boxers, the best thing you can do now is to go work three rounds on those stairs. They look at me with a little smirk on their face, like what am I going to get out of that? And, I... Read More »
How to Organize a Closet
How to Organize a Closet by Expert Village
Hi my name is Frank Clarke with Oliver and Associates Realty in London Ontario on behalf of expertvillage.com. I would like to speak with you briefly in regards to decluttering your closet space for the purpose of selling your home. This is a example of... Read More »
Framing an unfinished basement captainobvious Building & Construction 7 10-16-2009 11:53 AM
inexpensive way to make a damp dirt basement functional tmorrissette Building & Construction 7 10-12-2009 10:14 PM
Replacing a Section of Basement Floor lifeisgrand4me General Discussion 0 09-21-2009 03:08 AM
Patching unfinished basement ceiling? Pictures included stefonroman Building & Construction 2 03-02-2009 02:31 PM
unfinished basement brackh Electrical 17 02-14-2008 05:20 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
