Indoor Column...decorative Or Support. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-01-2011, 11:16 PM   #1
Indoor column...decorative or support.
Hi all first post here! =)
I am planning to rebuild my half-wall and turn it into a breakfast bar but I am concerned demoing the current half-wall. There is a column at the end of my half-wall and I am not sure whether this is a column is for support or decorative.
My set up looks like the following:
Any tips would be great! Thanks all!
renntecher is offline   Reply With Quote
Old 07-02-2011, 07:49 AM   #2
Rewards Points: 5,336
You would need to know whether the ceiling joists ran parallel or perpendicular to the 1/2 wall.
You should be able to determine this pretty easily.
You can try pushing the ceiling up next to the column on all 4 sides( about a foot away) and see where the beam is. Look in the basement and attic and see how those joists run.
You can cut a hole in the ceiling and look.
Ron
B. Franklin 1759
Old 07-02-2011, 08:13 AM   #3
the Musigician
DangerMouse's Avatar
Personally, I don't think it's going to be load bearing. Those half wall columns are normally just decorative.
DM
The Following 2 Users Say Thank You to DangerMouse For This Useful Post:
thomasjmarino (07-02-2011), tpolk (07-02-2011)
Old 07-02-2011, 09:28 AM   #4
KemoSabe
loneframer's Avatar
Don't assume anything. Go underneath the floor. If it's a bearing column, there will be support under it.
Also, try to free up the cap and lower it. Cut out a few inches of rock around the post and look for a structural beam above.
My guess would be that you'll find a flat block of lumber between the joists that serves as a nailer to attach the column top, but the only way to know for sure is exploratory surgery.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 07-02-2011, 10:06 AM   #5
the Musigician
If you're tearing it out anyways, just open the wall under the bottom of the column, if it's a support, it'll continue through.
If it's hollow, it's decorative. If you're not tearing apart the half wall, perhaps a long drill bit will tell you if it's continued or hollow.
DM
Old 07-02-2011, 10:25 AM   #6
Custom Home Builder
From your photo it really doesn't look load bearing.
But it doesn't hurt to make sure.
thomasjmarino is offline   Reply With Quote
Old 07-02-2011, 10:33 AM   #7
kwikfishron's Avatar
Rewards Points: 90
Actually DM there are hollow fiberglass structural columns that look just like that.
I’m not saying that is though, a little more detective work is needed as said.
My guess would be that there’s a 4x4 from plate to block inside just to keep the end of the wall from moving.
kwikfishron is online now   Reply With Quote
Old 07-02-2011, 10:44 AM   #8
the Musigician
Good point. If it's fiberglass, you'd know that too if drilled. You'd SURELY know if there was a steel pole up the middle that way! Same with a 4x4.
I guess we've covered most bases here and he has numerous ways to check.
If he's tearing out the bottom too, he'll know in a hammer stroke or two.
renn: Let us know what you find out?
DM
Old 07-02-2011, 12:18 PM   #9
Wow guys thats a lot of responses - I appreciate all of your follow-up questions.
So what I did was cut open a part of the half wall and this is what I am seeing:
I wrote on the drywall to show you guys where the stud / joist ends for the half wall and I noticed that the joist / stud at the end doesn't reach all the way to the column. As you can see, the center of the column is just at the edge of the joist as I marked for reference.
I also checked out the basement and the floor joists run parallel to my half wall. My column is approx above this location in my basement ceiling:
Old 07-04-2011, 10:07 AM   #10
hey guys any input from the pics I posted?
Old 07-04-2011, 10:14 AM   #11
the Musigician
I thought you were just showing us there was no support under the floor and that the wall was hollow?
DM
Old 07-04-2011, 10:17 AM   #12
DM
Oh =)
I actually wanted some confirmation from you folks
With all this evidence, can I conclude that this column can be taken down?
Old 07-04-2011, 10:18 AM   #13
I trimmed the drywall a bit further and can see that the "studs" that I marked is made of two 2x6's
Old 07-04-2011, 10:19 AM   #14
the Musigician
I would guess yes. It does not seem to be structural in any way.
DM
Old 07-04-2011, 10:24 AM   #15
KemoSabe
loneframer's Avatar
Judging by those pics, there's no chance that column is structural.
That's not to say it's not being used for structure though.
If it was designed to carry load, there would be some type of structural beam or other support underneath to pick up the point load.
I'd still drop the column cap and explore some before losing it completely. You can never be too safe.
Old Weather Head support connection problem RMCNABB Electrical 2 06-17-2011 05:27 AM
Sunroom extension support footings repair + cost gentlemansbeard Building & Construction 11 03-25-2011 03:40 PM
Alterative ways to support main beam frizbplaya Building & Construction 8 01-29-2011 12:10 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 06:48 AM
