Increasing Basement Window Size - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-30-2010, 05:30 PM   #1
Increasing basement window size
As I am plugging away at finishing my basement a few things have come up. I framed a bedroom in the basement but the window in the room is very small 10" x 24" this does not meet fire code as a means of egress (I should know!!)
How difficult is it to install larger basement windows? Am I affecting the foundation stability by cutting out part of it?
Any advice is appreciated.
FirefighterGW is offline   Reply With Quote
Old 08-30-2010, 06:20 PM   #2
Depends upon the wall, foundation etc
Any pic inside/outside of the area ?
Old 08-30-2010, 06:57 PM   #3
Rewards Points: 5,336
It's easier in a block foundation then a poured foundation. Easier in a sided house versus a brick or stone exterior.
Ron
Old 08-30-2010, 08:11 PM   #4
Registered User
Rewards Points: 5,212
"Am I affecting the foundation stability by cutting out part of it? " ------- not if you add a suitable header to carry the loads above, and it's not within 3' of the corner (or per local Codes).
Gary
Old 08-30-2010, 08:11 PM   #5
I will get some pictures up shortly. It is poured concrete and the house is bricked
Old 08-30-2010, 09:49 PM   #6
Tom Struble's Avatar
Rewards Points: 2,002
as you know with the basement windows not only is it the window size as far as egress goes,but also the well and being able to get out of that
Tom Struble is offline   Reply With Quote
Old 08-31-2010, 09:49 AM   #7
Concrete & Masonry
Rewards Points: 526
Yes, you should indeed!
The opening size has less to due with the dwelling occupant escaping on their own as it has to do with a fully equipped firefighter having enough room to gain access to the occupant.
As stated above, post a few pics here so we can help. I've done alot of these through the years (just bid one out last night actually) and have been through some strange ones as well. Anything is possible, but some are more complicated than others.
Two things I'll mention right away is:
Do it NOW, before you put in any drywall, finished flooring, etc......
Expect some fairly expensive/large equipment to be involved to execute this.
jomama45 is offline   Reply With Quote
new basement window (brick house) amakarevic Remodeling 7 01-26-2010 02:34 PM
Basement Window installation topher0524 Building & Construction 6 10-04-2009 05:46 PM
Basement window repair/replacement champers General DIY Discussions 7 08-19-2008 11:14 AM
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 11:51 PM
Basement ducting size??? firemanpato HVAC 1 01-15-2008 06:04 PM
