Inadequate Foundation? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-06-2007, 06:01 PM   #1
inadequate foundation?
long story, but I ended up taking my home BACK from a guy who screwed me pretty good. He ALSO put this big addition on here, no permits etc.. AND I think the foundation is not deep enough. it is only 24 inches BELOW grade. It does have cinder blocks on it then so the wood walls are sitting on 34 inches I guess but not below grade. This is a TWO story, I am in North indiana.. thanks in advance. I will be dealing with the local guys soon but want some education first. dan
sixty7flh is offline   Reply With Quote
Old 12-06-2007, 06:12 PM   #2
concretemasonry's Avatar
Rewards Points: 2,570
What is the required frost depth where you are?
You block foundation walls are probably much stringer than the wood above, no matter how badly they may be built.
If you are not below the frost line and want to avoid any heaving problems, take a look at the concept of "shallow frost insulating" or some thing like that in the 2006 IRC. It involves using rigid insualtion vertically and horizontally below grade to protect shallow footings. I am sorry I do not have a code handy, but htere is a concept that could help you avoid heaving and underpinning.
concretemasonry is offline   Reply With Quote
Old 12-06-2007, 09:00 PM   #3
ICF Construction
I have used the shallow footing detail concretemasonary is talking about, it is a real neat system and will save you many $$ in repairs.
Rule of thumb is (That I know of)
Standard 48" depth for frost level
Footing @ 36" needs 2" rigid foam 2' out from wall
Footing @ 24" needs 3" rigid foam 3' out from wall
Footing @ 12" needs 4" rigid foam 4' out from wall
Chris
Chris Johnson is offline   Reply With Quote
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 02:49 PM
I need help Re: Poured Slab Foundation - Moved to Plumbing alextina Plumbing 6 04-19-2007 05:35 PM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 10:27 AM
Addition Foundation /Build. advice wannabuild Remodeling 3 12-15-2006 07:28 PM
