Improving An Outbuilding's Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-23-2012, 01:03 PM   #1
Once a Pittsburgher, ...
Improving an outbuilding's walls
The property I bought came with a large shed, with electric (200A!) and water.
72'x46'.
The supports are 6x6s, spaced 12 ft apart on the long walls, 8 ft apart on the short.
2x6s wrap around horizontally, with 2x6 pieces nailed atop the 6x6s to hold the horizontals in place. That was a mouthful, here's a pic.
Siding is on the outside, and that's it. What should I do to install proper (plywood? pressboard?) walls? Insulation's an option, do I need that Tyvek stuff too?
Thanks!
Jay
Yinzer is offline   Reply With Quote
Old 06-23-2012, 01:09 PM   #2
More info: 10 ft ceilings, red clay floor.
Rain seeps in thru the bottom, rendering the first two feet inside on the north and east walls unusable for a couple days after downpours. Gutters would probably help there immensely.
Old 06-23-2012, 02:01 PM   #3
Rewards Points: 6,652
First thing is solve the water intrusion problem. You may have to build up a berm outside to redirect the water, then for the floor, have a few truck loads of crushed concrete or rock brought in, so you can build up a base. Then you can decide if you want to pour a slab or not later. As for insulating. You could float a wall around the inside perimeter, but I would do it after you get a slab down, so that it will be easier to do it.
Then again, there is always the possibility of taking 4x8 sheets of play, put 1 or 2 inch XPS on it, glued, then hang on the members. The seams you can just use 1x4's to place over. Those are the only couple of things I can think of.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 09:20 AM
No Floating walls where there should be! DIY Master Building & Construction 1 02-23-2011 05:06 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 01:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 04:12 PM
