-   -   Improving an outbuilding's walls (http://www.diychatroom.com/f19/improving-outbuildings-walls-148007/)
Yinzer 06-23-2012 02:03 PM
1 Attachment(s)
The property I bought came with a large shed, with electric (200A!) and water.
72'x46'.
The supports are 6x6s, spaced 12 ft apart on the long walls, 8 ft apart on the short.
2x6s wrap around horizontally, with 2x6 pieces nailed atop the 6x6s to hold the horizontals in place. That was a mouthful, here's a pic.
Siding is on the outside, and that's it. What should I do to install proper (plywood? pressboard?) walls? Insulation's an option, do I need that Tyvek stuff too?
Thanks!
Jay
Yinzer 06-23-2012 02:09 PM
More info: 10 ft ceilings, red clay floor.
Rain seeps in thru the bottom, rendering the first two feet inside on the north and east walls unusable for a couple days after downpours. Gutters would probably help there immensely.
gregzoll 06-23-2012 03:01 PM
First thing is solve the water intrusion problem. You may have to build up a berm outside to redirect the water, then for the floor, have a few truck loads of crushed concrete or rock brought in, so you can build up a base. Then you can decide if you want to pour a slab or not later. As for insulating. You could float a wall around the inside perimeter, but I would do it after you get a slab down, so that it will be easier to do it.
Then again, there is always the possibility of taking 4x8 sheets of play, put 1 or 2 inch XPS on it, glued, then hang on the members. The seams you can just use 1x4's to place over. Those are the only couple of things I can think of.
