Improvements In Which Order - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-08-2011, 07:57 AM   #1
Rewards Points: 18
Improvements in which order
Good Morning,
1970 one story ranch. If on a segmented budget, in which order would you recommend doing these improvements so as to not affect each next step. Don't want to have to partially disassemble [undo] anything from the previous step:
New roof
Vinyl facia and soffits
Gutters and downspouts
Vinyl siding
New windows
Many thanks,
Mike
389poncho is offline   Reply With Quote
Old 06-08-2011, 10:35 AM   #2
DIY staff
Rewards Points: 7,174
roof
windows(use new construction--with a flange---
then soffit and facia
siding
gutters
Let's see what a siding/exterior guy(or gal) has to say----Mike----
Old 06-08-2011, 04:21 PM   #3
kwikfishron's Avatar
Rewards Points: 618
Not enough info for me to call.
Obviously if you have any leak issues that should be dealt with first.
I’d normally say roof first but if the roof has a few more years left in it and you have rotten siding and leaking windows then maybe the roof should wait.
If you have do them separately then what’s if the worst shape? What’s most likely going to cause damage to the frame or interior of your house?
kwikfishron is online now   Reply With Quote
Old 06-10-2011, 10:58 AM   #4
Rewards Points: 18
Thanks so much for the replies. We've had a long power outage so just getting back to you.
Well, the roof is definitely the trouble spot so I guess that would be first. The other items are just old and original but are all still sound.
Thank you,
Mike
Which order? Many things to re-model 6fthook Remodeling 6 07-18-2011 02:55 PM
Painting order noone Painting 2 05-15-2011 10:34 AM
Ideal order of doing improvements zurich78 General DIY Discussions 7 03-07-2011 06:30 AM
Septic Order coming from Shower Drain CherylB1216 Plumbing 1 03-15-2009 05:16 PM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
