Old 10-03-2007, 09:41 PM   #1
I'm going to build a partition wall..
I'm going to build a partition wall in my living room. Would you nail or screw the base plate into the foundation? If screwing can I use regular tapcon screws? If nailing it, are there any framing nailers that will nail through the stud into the foundation? I went to home depot and was told that the Senco would go through the stud and into the foundation. Any suggestions?? Thanks
flyboylr45 is offline   Reply With Quote
Old 10-04-2007, 12:53 AM   #2
Mod / ArchiBuilder
Cole's Avatar
Just to clarify, you are type of foundation do you have?
Wood, Concrete?
Cole is offline   Reply With Quote
Old 10-04-2007, 08:50 AM   #3
it is a concrete foundation.
Old 10-04-2007, 03:57 PM   #4
Barry M's Avatar
I'd use a powder actuated nailer. I've used the 22cal one from Remington to do exactly the same thing, a partition wall on concrete several times with great results. You can probably rent one from a tool rental store or I know Lowes sells them.
Barry M is offline   Reply With Quote
Old 10-04-2007, 04:16 PM   #5
Your just adding a wall to your livingroom, right?
Cant you just screw the bottom plate into the floor joists?
Jeekinz is offline   Reply With Quote
Old 10-04-2007, 04:45 PM   #6
Floor joist?? It is on a concrete foundation. I knew I could use a powder actuated nailer. I was curious because the lady at HD said that the Senco framing nailer could go through the base plate and into the concrete foundation. That sounded a little strange to me. I am going to buy a framing nailer and was thinking of the Porter Cable FR350A. There is a $100 difference between the PC and the Senco. What do you guys recommend??
Old 10-05-2007, 10:56 PM   #7
remodeling pro
Sounds like her brother must be the factory distributor for repair parts.
Either use the powder actuated , or drill with a rotary hammer and drive some "Rawl" deformed shank pins in. The Tapcons would work, but I find them too finicky, needing a very accurate hole to work correctly.
Either gun will work okay. Over the long haul for tough everyday use, the top line Senco will out last the other, but most of the Senco guns at HD are the lower end models, thus I would put your choices as a toss up.
troubleseeker is offline   Reply With Quote
Which do Generally prefer for partition wall framing? J187 Building & Construction 3 05-01-2007 01:33 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
