Ill Effect Of Heavy Block Steps On Basement Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-21-2011, 12:45 PM   #1
Ill Effect of heavy block steps on basement wall?
We live in a Cape Cod home with a one car driveway. Along the side of the house were rotted wooden steps leading out of a side door. I'd like to replace the steps with some limestone block (2 slabs). The foundation where the steps would go has some cracking and is out of plumb less than one inch. I've taken care of the water issue but I worry about the heavy steps pushing the wall in further. Is this something to be concerned about?
smawgunner is offline   Reply With Quote
Old 06-21-2011, 04:27 PM   #2
Rewards Points: 5,336
The base you provide the steps should be such that they are free standing and exert no pressure in any direction except down.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
concretemasonry (06-21-2011)
Old 06-21-2011, 04:35 PM   #3
concretemasonry's Avatar
Rewards Points: 2,608
smawgunner -
Even with lightweight steps, your step foundation wall has already failed or is starting to fail based on the cracks and deflection. Aparently, due to moisture collection, poor soil backfill and the lateral pressure of the saturated soil.
Definitely make any added steps isolated to avoid adding more lateral loads that will compound the problem.
concretemasonry is online now   Reply With Quote
Old 06-21-2011, 04:53 PM   #4
Originally Posted by concretemasonry View Post
smawgunner -
When you say make the steps isolated, what are you referring to? At one time the wood steps were actually attached to the house and supported by the block foundation. I spoke to a cement contractor who wanted to reattached to the block/foundation to support a poured step (at $2000.00 no less). I thought that would be the worst of the two evils with all of the weight hanging on the foundation. But now I'm not sure. It's a small two riser step that I'm trying to replace.
Old 06-21-2011, 06:07 PM   #5
Isolated and freestanding are the same animal.
They are not connected to the house structure.
Ron
B. Franklin 1759
Old 06-21-2011, 07:57 PM   #6
Then again, cars have been driving on the driveway which is 2.5 feet away from the foundation for years so I'm not sure if the block/stone steps would make a huge difference....???
Old 06-21-2011, 08:08 PM   #7
You lost me with that post.
Ron
B. Franklin 1759
Old 06-21-2011, 10:04 PM   #8
Think about it now.......if cars park on the driveway which is approx. 2.5 feet away from the foundation. I doubt heavy stone sitting that close would be any different. If I could...I'd draw you a picture if you think that would help.
Old 06-21-2011, 10:26 PM   #9
If it's built properly, most of the force should be vertical, so there should be no damage to a nearby structure that is sound.
But I do like pictures.
Ron
B. Franklin 1759
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Help getting paint off block wall butchbs1985 Painting 4 06-09-2011 07:20 PM
Bathroom Remodel - Resurfacing Plaster over Concrete Block itcanadian Remodeling 2 05-30-2011 10:10 AM
Cinder Block Basement Remodel raxtman Building & Construction 7 07-16-2010 01:37 PM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 10:24 PM
