Old 06-09-2011, 10:51 AM   #1
If anyone has faux stone on their foundation.. remove it!
I bought a home with faux stone on my foundation. I was going to fix it since the previous owner rammed it with his car and broke some.
After poking around, I noticed it would be a way better idea to just rip it all off.
We had been having a lot of trouble with ants in the front rooms.
When I started ripping off the fiberglas stone, all the wood behind it was either rotten, covered in ants, a stalking grounds for HUGE spiders, it was just nasty nasty nasty.
Not good to have that much wood so close to the ground, and right up on your house.
I feel sooooo much better with it gone.
So this is for anyone out there that has the same stuff!! Get it off!!!
hanleyster is offline   Reply With Quote
Old 06-09-2011, 10:57 AM   #2
sounds more like someone installed it wrong..... fiberglass faux stone? all i've seen installed around here is stone vineer which is concrete basically, never seen fiberglass... is it hallow or something? the stuff they put on houses here is solid and they put it onto a mesh that is covered in grout basically
BlueBSH is offline   Reply With Quote
Old 06-09-2011, 11:05 AM   #3
Wood was nailed into the foundation ( ) and then the fiberglass panels are nailed onto the wood slats. what a terrible idea!
http://www.fauxpanels.com/nailon-sto...e.php?color=54
Now I am afraid to yank the nails, I think I will just take them off with a grinder instead?
Old 06-09-2011, 11:08 AM   #4
yuck, they should have gone with stone veneer... would have gone right onto the block with no furring... just mudded on
The Following User Says Thank You to BlueBSH For This Useful Post:
Willie T (06-09-2011)
Old 06-09-2011, 11:09 AM   #5
Originally Posted by BlueBSH View Post
yuck, they should of went with stone veneer... would of went right onto the block with no furring... just mudded on
if you yank them out you could fracture the block more and put a larger dent into it... just use a grinder and cut them to block level then maybe seal them with something to prevent rust
Old 06-09-2011, 04:16 PM   #6
those guys got paid & they're gone either it was the h/o OR some other ignoramus - then again, it could be a one-off material but i've never seen that stuff
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 06-09-2011, 04:19 PM   #7
after researching it myself out of curiosity that stuff is meant for indoor use only! so for it to be outside was wrong to start with
Old Stone Foundation Repair Nivk Building & Construction 17 02-02-2012 10:08 PM
underpinning a rubble stone foundation wall Knucklez Building & Construction 0 04-16-2011 10:12 PM
Installing Faux Stone on Interior wall nebulour General Discussion 5 10-13-2010 12:44 AM
crumbling field stone sandstone foundation...can we resurface the visible outside portion? btolt162 Building & Construction 2 07-06-2010 01:04 AM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 09:34 AM
