Identifying Joist Species - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-20-2010, 10:26 AM   #1
Rewards Points: 262
identifying joist species
The joist span tables I look at say you must know the species of wood to be able to calculate spanning properties correctly. Is there an easy way of identifying the species on 50 year old joists? Do I need to get a sample tested someplace, or are there any tricks to do it in the field?
tpagel is offline   Reply With Quote
Old 04-20-2010, 11:53 AM   #2
kwikfishron's Avatar
Rewards Points: 772
What part of the country are you in?
Can you post a picture of the wood?
kwikfishron is online now   Reply With Quote
Old 04-20-2010, 12:06 PM   #3
Rewards Points: 262
I am in Connecticut. Can't post a photo as I have not exposed the joists yet. This is my "next" project and i am trying to think ahead. Will post photos as soon as I am able. Thanks for your reply. Can you take a "guess" (I won't hold you to it) based on the region I live in?
Old 04-20-2010, 12:50 PM   #4
To get the modulus, E, support an on-edge joist at each end, step in the middle, then post midspan deflection, total span, joist actual dims and your weight.
The violin makers say that old wood gets stiffer, so the E would increase.
Alternately, slice off a small piece with the grain, near the end of a joist [the IRC has rules for this] and do the same experiment with a lighter weight.
These values can be used to calculate the inputs for this link,
http://www.efunda.com/formulae/solid...ple_centerload
or it can be done with a hand calc. or on a spreadsheet, using the link formula for Wmax and solving for E.
I = [1/12] bh³ where b is the beam edge width and h is the height.
and
w = PL³/48EI so E = PL³/48Iw
Knowing E, you don't need to know what type of material it is, be it wood, steel, copper, concrete. . .
Old 04-20-2010, 03:25 PM   #5
What are you trying to do ?
Old 04-20-2010, 03:51 PM   #6
Rewards Points: 262
Trying to decide whether I will need to sister the joists below if I build out an attic level into living space. Right now, there are 2x8 joists at 12" O.C. spanning about 16'-3". I "think" that this may not be up to code, so I was going to take out the living room ceiling and sister all the joists with 2x8's glued and nailed with 3" nails about about 6" on center. I was going to have to take out the living room ceiling anyway for another reason, so that's not such a big deal, and it will also let me add acoustic insulation between the levels. I need to do the span calculation to know whether I really do need to sister the joists. What do you think? 2x8's? 12" OC? Good enough or needing support?
Old 04-20-2010, 04:02 PM   #7
2x8 hem fir #2 grade 12" OC will span ~15' 7" 30psf
#1 gets you to 15' 10"
2x10's #2 grade will get you the span you need
Or add a support beam in the middle
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 09:15 AM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 02:18 PM
floor joist issue drtbk4ever Building & Construction 4 03-22-2009 10:20 AM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Cutting/drilling hole in joist - How big? curls00 Carpentry 3 07-20-2007 09:56 PM
