Ideas For A Plasticrete House? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-24-2011, 04:47 PM   #1
Caution! Girl working
Ideas for a Plasticrete house?
Hello,
You guys seem so knowledgable! I appreciate any input on this. Please bear with me, I promise there's a point to this post
About a year ago I bought a small house constructed of this block material called Plasticrete. It's built on a hill so the front is ground-level and the lower level is walk-out from the back. If you look up from any room in the lower level, the ceiling (which is obviously the floor of the room above it) is all block. It's pretty cool, built somewhere during the 1940s / early 1950s.
The exterior has a painted concrete brick-looking veneer and the anchors have been rusting for a while, as is evident by orange streaks here and there on the exterior.
The basement walls were painted (probably a million years ago) and there are a lot of places on the exterior below-grade walls where the paint is gone. I'm assuming it is from moisture.
So, my questions are 1) is the moisture wicking through from the ground since I'm sure there's no barrier on the below-grade exterior walls OR 2) since the veneer anchors are also rusting above ground, I assume moisture is constantly being created in the small space between the exterior veneer and the interior block. Of course, no one would have known about giving the water a place to go (no weeping ability here) back then. So, could that moisture be 'dripping' down in between the interior and exterior walls then, when it gets below grade, being absorbed into the basement walls?
And, finally, does anyone see a problem with my solution of installing (glue AND anchoring) fir strips with foam insulation between them and vinyl siding to minimize the temperature difference between the inside and the outside of the building. Leave it to me to move to Connecticut during the worst winter on record...shesh.
Thank you!!!
-Danielle
ADaniLion is offline   Reply With Quote
Old 04-29-2013, 07:48 PM   #2
Plasticrete Issues?
Danielle: Plasticrete blocks were common in the seventies, they fell out of favor when they were sued by developers in NYC after a failed application in which you guessed it "water seepage through blocks" was a problem. Do not seal the veneer or the block as it will cause degradation of micritic bond, over the years the blocks have mineralized to some degree which is good ie: they are turning to stone. You can paint them with slacked lime with a light grout color added nothing else. Andre Miannay StoneWorx and Preservation 702-582-1156
cementech is offline   Reply With Quote
The Following User Says Thank You to cementech For This Useful Post:
jagans (04-29-2013)
Old 04-29-2013, 08:33 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Interesting post cementech, I hope you will post more.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Weird wiring in house fdmillion Electrical 13 06-14-2013 06:49 PM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
Brainstorming ideas to Dress Up the front room of my new house!! the_d_mann1 Interior Decorating 0 05-01-2011 04:47 PM
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
