Idea For Small Gap When Replacing Exterior Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-20-2008, 06:46 PM   #1
Idea for small gap when replacing exterior door
I replaced an old, broken exterior door with a new one this weekend and the project went great. The question I have is the brick molding on the old door was slightly wider than the brick mold on the new door so I now have about an 1/8th inch gap between the edge of the molding and the J channel for the vinyl siding, I can see the housewrap in the gap.
Is the easiest fix to simply back out the siding and move the J channel flush against the door? I figure I can move the track over and still have the siding go under the J channel?
Thanks for the help
Littlerhody is offline   Reply With Quote
Old 04-21-2008, 06:40 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
This may cost you only your time and a small tool:
See if you can unzip the siding to access the J channel.
Possibly you have enough room to: Pull the nails out that are holding the J cahnnel, and move the channel over 1/8".
Then re-install the siding under the channel.
You need a vinyl siding "unzipping tool" for that. Most Big Hime Improvement stores have them.
- Build Well -
Rusted-out closet flange found when replacing toilet; what to do? kevind Plumbing 16 09-23-2011 08:00 AM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Carpet Idea...Will It Work? Topazprincess77 Flooring 1 03-19-2008 10:47 AM
Replacing Old Windows pyrogen74 Remodeling 1 02-09-2006 06:53 PM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 08:50 AM
