Idea To Finish Around Water Supply Linr And Water Meter - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-08-2013, 07:35 PM   #1
bryanp22's Avatar
Rewards Points: 288
Idea to finish around water supply linr and water meter
Any ideas what I should do to finish around a water supply line and meter? I've attached a couple pictures. It's almost half way down the wall. So far my only idea is to create a build end end table around the meter with a top that is removable for top for future water meter servicing. I looked on google images and Pinterest but I didn't see much.
Idea to finish around water supply linr and water meter-image-208093652.jpg   Idea to finish around water supply linr and water meter-image-574420345.jpg
bryanp22 is offline   Reply With Quote
Old 07-08-2013, 09:35 PM   #2
Bill Kearney
Rewards Points: 1,174
Bear in mind you want that shut-off valve to be EASILY and QUICKLY accessible. If/when there are water problems you do not want to have to waste time trying to get at that valve.
What're you going to be doing to the rest of the room? Would this be a good area for a bookcase? Something like that would let you also cover the pipe going up the wall.
And are you not insulating the walls?
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
jaydevries (07-08-2013)
Old 07-08-2013, 10:23 PM   #3
bryanp22's Avatar
Rewards Points: 288
I am insulating the walls, but it will still probably stick out six inches or so. I was going to put an access panel on the side for a quick shutoff. It will just take moving a couch to access.
Old 07-08-2013, 11:38 PM   #4
looks like a good place to frame a small closet that would hide the meter and the cleanout in the floor.
Old 07-10-2013, 01:16 AM   #5
bryanp22's Avatar
Rewards Points: 288
Closet in the middle of the room seemed like it would look weird to me I guess.
Old 07-13-2013, 04:29 AM   #6
Rewards Points: 1,442
What about a bench with a removable top? Could also double as storage.
mikegp is offline   Reply With Quote
