ICF Vs. Wood Framed - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 01:39 PM   #31
Rewards Points: 1,092
Jack: Another option, if available in your area, is the ThermoMass wall, where foam is sandwiched between concrete. THAT sounds like it will solve any bug problems. As for the numbers reported above, they are not that way for me, so I guess everyone has to run their own. Greenbuildingadvisor.com has some good info on ICFs. Enjoy the new pad. j
Old 11-01-2011, 04:14 PM   #32
Originally Posted by itsreallyconc View Post
you'll invest a bit more for icf - typically 10%,,, however the amortization of the addl exp is about 18mos of energy savings,,, after that, is always less $$ out of your pocket,,, then add in the addl strength & lack of exterior noise,,, if electrician can't learn to pull wire in 2hrs, get another guy,,, when we applied our stucco coat, the mesh was stapled directly to the icf's exterior surface.
i've built w/wood & icf's & our next home will be icf,,, as dick (concmasonry) posted, are you building for short-term or not
That was my other question. How do you find electricians, plumbers and drywall contractors that know how to work with ICF?
To answer your other question. This would be a custom home that I would live in until I died. In other words, it is long term home. If it were short-term, I would just buy a tract home.
JackOfAllTrades is offline   Reply With Quote
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 08:46 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
