Ice Dams Form At Corners Of Roof Only?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-03-2008, 02:05 PM   #1
Power Gen/RS Engineer
Rewards Points: 566
Ice Dams Form At Corners of Roof Only??
Last winter, I noticed that my house was developing ice dams at the corners of the roof only. I have read many sources suggesting that ice damming is caused when the inside/attic temperature is higher than the outside temperature which causes the snow to melt and run down to the eave. Since the soffit is not above the conditioned space of the house, the water then freezes at the roof line.
When ice dams form, do they usually do so at the corners of the house? Can anyone think of a reason as to why this may be occurring?
Thanks!
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 10-03-2008, 04:30 PM   #2
47_47's Avatar
Rewards Points: 44
You may be losing heat into the attic from the walls.
47_47 is offline   Reply With Quote
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
