Icciles Comong Out Of Soffit Vents - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-15-2014, 12:29 PM   #1
Rewards Points: 150
improper flashing?
I had a small addition put on the back of the house with 2 velux skylights (CS 6000 ?) installed on each side. Was out pulling some snow off the roof and noticed icicles hanging from the soffit vents in the area directly below the skylight (approx. 3' ) from soffit vent. Any thoughts why this might be happening?
hpyjack2013 is offline   Reply With Quote
Old 02-15-2014, 12:32 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 898
Heat getting into that rafter bay is probably the easiest answer.
Old 02-15-2014, 12:41 PM   #3
Rewards Points: 150
10" of fiberglass insulation, 1/2 rigid, 1/2 pine ceiling, Think heat is getting in through side walls of skylight? both side identical, problem the same on both sides, soffit extends out from house 18"
Old 02-15-2014, 01:14 PM   #4
Rewards Points: 898
T&G interior?
Old 02-15-2014, 01:17 PM   #5
Rewards Points: 150
yes it is
Old 02-15-2014, 01:24 PM   #6
Rewards Points: 150
icciles comong out of soffit vents
Had a new addition put on with new skylights installed on each side ( velux cs6000). ceiling is insulated with ridge vent, 10" fiberglass, 1/2" rigid board and covered with 1/2 t&g pine. I have icicles hanging from the soffit vents in the area directly below the skylights (approx. 3" from skylight) soffits are approx. 18" wide ,why is this happening?
thanks
Old 02-15-2014, 01:47 PM   #7
Rewards Points: 3,396
thanks
It's winter ???
ritelec is offline   Reply With Quote
Old 02-15-2014, 01:51 PM   #8
Kidding aside.......... and if I understand your question...........
probably the same answer you came up with....
Condensation
Warm air in the skylight area, meeting the external air.....
may be some moister building up in your new roof soffit area too....
maybe not
Old 02-15-2014, 01:56 PM   #9
Rewards Points: 6
My guess is that the joist bays under the skylights aren't vented so heat/moisture is building up.
Dan
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
hpyjack2013 (02-15-2014)
Old 02-15-2014, 02:05 PM   #10
Rewards Points: 150
skylight fills full space between roof rafters. I suppose it also stops circulation from soffit to ridge vent. I'm afraid condensation is going to start running in walls. problem solver?
Old 02-15-2014, 02:22 PM   #11
Where's the contractor or designer ???
what to do know? Today ?
Sorry..... no suggestions...
Try not to loose sleep over it........ sounds like the moister is working it's way outside (the icicles) not inside....
and if it does... (which it won't ) nothing you could do right now anyway....
cleansing breaths.in through the nose out through the mouth..
Old 02-15-2014, 02:33 PM   #12
Rewards Points: 444
In my opinion Skylights and Can Lights rate well up in the top numbers for being the worst inventions for residential buildings ever. I solved my problem after 20 years of the aggravation. I just don't have the Cans taken care at the moment.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 02-15-2014, 02:42 PM   #13
What your solution was kinda crossed my mind but didn't want to say anything..........................
Was also thinking yesterday as I was removing a ton of snow...........
why would anyone get a sun roof or moon roof for a vehicle....??
anyway...
The Following User Says Thank You to ritelec For This Useful Post:
Old 02-15-2014, 03:57 PM   #14
Rewards Points: 150
thought crossed my mind, but I put them in for summer time ventilation.
Old 02-15-2014, 03:57 PM   #15
Rewards Points: 150
contractor is on his "way"
Vinyl Perf Soffit over Wood - No Vents nickelshine Roofing/Siding 18 05-29-2012 10:12 AM
Ridge Vent with No Soffit Vents? Is it possible? NTL1991 Roofing/Siding 4 05-14-2012 03:08 PM
Hidden Soffit Vents Mucluk Building & Construction 4 01-26-2012 09:15 AM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 11:13 AM
Knee wall w/ soffit vents no ridge vent -- seal soffit vents? tblaz Roofing/Siding 1 04-24-2011 05:12 PM
