I Want To Pour A Small Slab... Any Pointers? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-17-2010, 04:44 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I want to pour a small slab... Any pointers?
I want to get my pump system and 50gal hot water heater out of the garage. Way too cluttered the way it's set up, and I figure if I can just attach a small outbuilding to the side of my house, it'll give me a little more space in my already small garage, as well as cleaning up the plumbing to the pump system and water heater, and preventing any leaks from flooding the garage.
It's going to be a pretty small slab, probably 3'x6', and the ceiling will only be tall enough to accomodate the water heater.
How thick do I need the slab to be?
Do I need rebar in it, or can i just buy a sheet of that wire mesh?
Frost line here is only 4-6" below grade (I've never seen it get below 28* in my lifetime) do I need to pour footings for a small slab like this? If so, how large do they need to be?
If I'm missing any info, let me know and i'll provide it ASAP.
Journeyman Plumber
Old 04-17-2010, 06:30 PM   #2
joed's Avatar
Rewards Points: 12,016
2x4 for forms. No rebar or wire mesh. Clear the ground and put in a good 4-6 inches of drainage stone.
Old 04-17-2010, 06:46 PM   #3
Civil Engineer
Rewards Points: 4,572
You do live in the People's Republic of California, so you may need a building permit. If so, the building inspector can undoubtedly tell you what code requirements are for an attached or detached outbuilding, whichever you are building.
Prepping a slab for kitchen island tiger275 Plumbing 10 05-02-2009 05:03 PM
See Picture - To what Level pour slab? seth Building & Construction 4 04-27-2009 08:06 AM
question on suitability of monolithic slab rtoni Building & Construction 5 03-31-2009 06:18 PM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 06:14 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 01:32 AM
