I Want To Install A New Keyed Doorknob Set In A Bedroom Door-but The Latch On The Old One Is Stuck Into The Wood - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-24-2011, 03:54 PM   #1
I want to install a new keyed doorknob set in a bedroom door-but the latch on the old one is stuck into the wood
I bought a new keyed door knob--but when I removed the old doorknob and then tried to remove the latch from the wood frame ( the thing that actually fits into the strike plate) it is like it is glued or something in place and I couldn't even pry it loose---how do I get it out of the wood?
bobry is offline   Reply With Quote
Old 09-24-2011, 04:15 PM   #2
Rewards Points: 5,336
First you remove the screws on the latch. Some latches are circular, friction fit units, so no screws. Then you insert a screwdriver into the hole the spindle went through. Take a hammer and hit it from the hinge side so you drive the latch out of the door. It should take a few medium taps to get it started.
B. Franklin 1759
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
how to install wood molding around window ctsgroi Carpentry 10 09-08-2011 04:47 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 09:00 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 05:29 PM
