Old 01-30-2011, 10:20 PM   #1
i used Acrylpro to set backerboard
I was told to use Acrylpro to set tile on my kitchen counter top. I have 2 sheets of plywood 3/4" and 1/2" under HardiBAck backerboard. I used the Acrylpro to set the backerboard and screwed it down. I found out later that this stuff is more like a mastic than a thin set. Will this be ok to go ahead and use thin set to set the tile or do i need to take up the backer board and start over and use thin set under the backerboard? we are planning to set travertine tile
Tim5150 is offline   Reply With Quote
Old 01-31-2011, 02:42 AM   #2
It will be fine. The hardi will not move either way. You probably didn't need to you the acrylpro. You have a lot of material on top of your cabinets (why?).
proremodel is offline   Reply With Quote
Old 01-31-2011, 05:21 AM   #3
It's an older house, The floor was tiled around the cabinets. It had an old built in oven, I needed the height to fit a a standard slide in oven. I heard that Acrylpro crap never sets up like it doesn't when its in the bucket. Will it eat at or hurt the plywood over time?
Old 01-31-2011, 05:47 AM   #4
Contractor - Renovations
fungku's Avatar
Out of curiosity, how thick did you put it on? What size trowel?
fungku is offline   Reply With Quote
Old 01-31-2011, 09:04 AM   #5
i used a 1/4" trowel
Was told to buy Acrylpro gcushy Tiling, ceramics, marble 17 12-29-2010 07:49 PM
Is it proper to tile over chipboard if backerboard is first laid? wvueers2004 Flooring 7 10-13-2010 06:22 PM
Question about how to position backerboard for shower Swazzle Remodeling 3 08-03-2010 06:11 AM
Backerboard question shaggyb Tiling, ceramics, marble 4 01-31-2010 02:03 PM
Backerboard and Tile Project Question Livestrg05 Flooring 6 04-25-2009 08:35 AM
