I Need To Support A 1000 Lb Bathtub - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-25-2009, 04:41 PM   #1
i need to support a 1000 lb bathtub
Help! What kind of structural support do i need to support a 1000+ lb bathtub? Specs say 800 Lbs with water.
Have a pier and beam foundation and am installing a wider deeper tub which i would like to drop down in the floor about 6" or so. I got joist hangers, but I'm sure there is more to this than meets the eye. Want to make sure I give it the proper structural support.
Sasha2000 is offline   Reply With Quote
Old 01-25-2009, 04:57 PM   #2
Registered User
Termite's Avatar
Unfortunately your question is much too general for us to be able to begin to assist you. There are a number of variables that must be evaluated in order to know what it will take to support it. Those variables include span of the floor joists, joist spacing, grade of lumber, other loads on the floor system, etc.
My advice would be to contact a structural engineer in your area that does small residential jobs like this. They'll need to visit your home and evaluate its structure to determine what will work best.
Temporarily remove basement support post ColinD Building & Construction 14 12-04-2008 05:07 PM
Adding support to "springy" floors-this mom's got to do it herself! LOStouten Building & Construction 10 11-12-2008 08:38 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
bathtub support abc Plumbing 8 01-26-2008 09:52 PM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
