I Need To Make A Waterproof Hole - Can I Use Concrete? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-18-2011, 03:33 PM   #1
Rewards Points: 264
I need to make a waterproof hole - can I use concrete?
I am trying to make a waterproof hole. I've already dug the hole (actually seems to be pretty waterproof already, because the ground is clay)
Here is what I'm thinking of doing:
Pouring a floor with Quickcrete vinyl floor patch
Putting a plywood form in the hole
Adding walls
Covering it with epoxy (is this even necessary?)
Will this work? Is there a better way to do it?
tibberous is offline   Reply With Quote
Old 12-18-2011, 03:47 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What on earth are you doing exactly? What's the final goal of this scenario?
XXX
Old 12-18-2011, 04:17 PM   #3
Rewards Points: 264
Nutrient res. for a hydroponic system
A waterproof hole
Old 12-18-2011, 04:21 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
How big is this hole exactly?
I wonder if city grade PVC piping could do. (the big green ones you see at construction sites) Not sure where you'd buy such pipes though. You could then glue a flat surface at the bottom as a cap, unless you can get caps for those pipes. Concrete is not 100% watertight, though if all you're looking for is a temp holding area, it could do. Problem is, if it freezes, it will crack.
Old 12-18-2011, 06:43 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,630
Adding walls
Ayuh,... How Big is it,..??
You could dig a hole 2' wide, 'n 3' deep, then drop in a plastic 55 gallon drum...
A water tight hole, with 2, 2" bungs in the top...
Bondo is online now   Reply With Quote
Old 12-18-2011, 07:11 PM   #6
Wire Chewer
Rewards Points: 132
Good idea never even thought of a drum. Probably easier to get too!
Old 12-18-2011, 08:20 PM   #7
Knucklez's Avatar
Rewards Points: 932
you can get rain barrels from the city water works department usually pretty cheap. once a year they give them away free where i am.
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 12-18-2011, 08:29 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 548
Come by my house and I will give you about 15.
I tore out an old floating dock, and now I have all these barrels.
Seal hole in concrete - hitch, wire coming out BlueBSH Building & Construction 1 03-14-2010 10:34 AM
How Make Hole In Cement For Chimney? Aurelius Building & Construction 6 11-16-2009 12:27 AM
Trying to waterproof a concrete pool Northern Landscaping & Lawn Care 4 01-27-2009 12:40 PM
Filling hole in concrete floor? Frank_N_Stein General DIY Discussions 3 01-03-2009 12:10 PM
Hole in the concrete slab shapeshifter Flooring 5 10-15-2007 06:45 PM
