I NEED To Cut A Piece Of Staircase Stringer Out! - Building & Construction - DIY Chatroom Home Improvement Forum
View Poll Results: do i cut the stringer?
yes, it will still support fine 0 0%
yes, but reinforce in 0 0%
no, don't cut that piece out of that stringer. 7 100.00%
Multiple Choice Poll. Voters: 7. This poll is closed
Old 09-14-2013, 12:02 AM   #1
I NEED to cut a piece of staircase stringer out!
We are converting this valuable under staircase closet hallway space into a pantry accessible through the kitchen by moving the door. we want the pantry door to go left of the fridge, (fridge is being pushed in to the pantry space as well, framed in by the 2 sets of 2X4's in the pic.) BUT the door runs right into our stair stringer! we only need about 5" across and 4" down cut out of this area, but im sure it would compromise the integrity of the stairs,,, right?? is there a way we can cut the little piece out and reinforce with something small (L bracket??) we could cut the top corner of the door, but it is not a good height for normal people then...
I NEED to cut a piece of staircase stringer out!-stairproblem.jpg   I NEED to cut a piece of staircase stringer out!-photo-3.jpg
rlc05n is offline   Reply With Quote
Old 09-14-2013, 02:19 AM   #2
Rewards Points: 626
sorry I would not be even thinking of cutting that. what you want and what you have are two different things sorry your plans are not going to happen unless you want to redo the stairs and build it the way it needs to. Just my advice. But hey your home.
Nailbags is offline   Reply With Quote
Old 09-14-2013, 02:48 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 184
I agree, it will weaken the stairs way too much.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 09-14-2013, 05:50 AM   #4
Rewards Points: 502
A simple steel bracket would not do.
However, if you live near a steel fabricator, get them to cut a sheet of 1/8th or 3/16th steel plate approximately to the shape shown.
Screw or bolt it to the stringer.
The cut seems to be fairly near the top of the flight so the bending stress in the stringer will be low.
tony.g is offline   Reply With Quote
Old 09-14-2013, 08:06 AM   #5
joed's Avatar
Rewards Points: 11,988
Turn your picture right side up before you post them.
The Following User Says Thank You to joed For This Useful Post:
Blondesense (09-16-2013)
Old 09-14-2013, 08:28 AM   #6
Cutting the door and building a custom jamb is the only way I would do it. Too many safety issues with notching the stringer IMO.
jponto07 is offline   Reply With Quote
The Following User Says Thank You to jponto07 For This Useful Post:
joecaption (09-14-2013)
Old 09-14-2013, 08:32 AM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
the only way i could making something remotely work would be to skip the stringer idea and put cleats on the walls. and up the thickness of the tread stock to 1 1/2"
woodworkbykirk is offline   Reply With Quote
Old 09-14-2013, 09:21 AM   #8
Rewards Points: 216
my neck is hurting again.
that bracket would work. but if it were mine, i would also have some angle iron welded to the notched area.
Fix'n it is offline   Reply With Quote
Old 09-14-2013, 09:48 AM   #9
Bill Kearney
Rewards Points: 1,174
Please, rotate your pictures first BEFORE posting them.
Why are you wanting to cut it? For a pantry door or the refrigerator?
If it's the entry door then what about just framing out the wall a bit and keeping a rectangular door? Then just leave the bit of diagonal behind it. We'll be doing that for an upstairs closet under some attic stairs. From the outside it looks normal, but inside there's a small diagonal of the riser.
And what is that along the top of the opening? A joist, but only nailed the side of what looks like a post? Why does it not have lumber under it, supporting it from below?
I would not cut out the stringer.
wkearney99 is offline   Reply With Quote
Old 09-14-2013, 02:11 PM   #10
recently retired
Rewards Points: 280
Tony G. posted the solution for you. I would make the plate thicker, a bit longer and use PL Premium adhesive in addition to lags. Make sure all other connection points are secure.
Keith Mathewson is offline   Reply With Quote
Old 09-14-2013, 06:10 PM   #11
BIG thanks for all the help!
THANKS SO MUCH FOR THE REPLIES!
I am going to go with the fabricated plate answer i think. I live in houston, so i shouldn't have any trouble finding the metal shop.
IF I were to put a rectangular door on in front of the stringer and keep the lower hanging bit of stringer as wkearney99 suggested, would that be against any doorway, ceiling, or pantry entry height codes?? I hope no one over 5'8" buys the house...
You guys make up such an amazing community of knowledge; I hope one day I will be experienced enough to contribute.
-Rachel
Open-Riser Staircase Help - Convert or Rebuild? lohryx5 Remodeling 18 06-24-2013 01:06 PM
Trimming a finished piece to make room for a larger refrigerator bethesda Carpentry 3 10-08-2012 08:09 PM
Trimming a staircase Richo Carpentry 38 09-30-2010 10:13 AM
Need to build stairs--Is there a Stair Kit? Cocoxoxo Building & Construction 13 04-15-2010 09:52 PM
Removing single piece of siding shortagain Remodeling 4 01-02-2006 11:12 AM
