I Need Advice On Removing A Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-17-2010, 10:27 PM   #1
I need advice on removing a wall
My house is square with a bedroom at each corner and a shared closet between each bedroom. I am thinking about removing the closets and making two large rooms instead of 4 9x12 rooms. I am unsure if the walls are load bearing and if i need permits or inspectors or anything to come out before doing the work. None of the walls I am thinking of removing have plumbing, gas, or electrical running through them. Any advice on how to go about finding out if they are load bearing or not. If it helps I made a drawing of the layout. The walls I want to take out are crossed off in red.
tyler7c is offline   Reply With Quote
Old 10-18-2010, 01:25 AM   #2
STRUCTURAL
Check the direction of the ceiling joists. If they sit on the walls in question then they are load bearing.
If the joists on the wall are the bottom chord of the roof truss then the walls may or may not be load bearing, an inspector needs to look at them to determine that.
If the ceiling joists are in the other direction it means that they are not set on these walls then the wall is not load bearing.
________________________________________________
CHM Consultants Engineers
404-664-4989
infoCHM@Gmail.com
ENGINEER10 is offline   Reply With Quote
Old 10-18-2010, 10:10 AM   #3
Ok so they are load bearing walls. Would it be stable enough to open up walkways through the walls but leave a couple feet on either side and on the top?
Old 10-18-2010, 11:14 AM   #4
jlhaslip's Avatar
Rewards Points: 2,884
With a properly sized header above the walkway opening you would be alright.
Your local building inspector or a structural engineer would know which header to use.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-18-2010, 11:38 AM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 792
You can also run a beam in the attic above the ceiling joists and tie the ceiling joist to the beam. The ends of the beam must have a support to sit on top of the plate of the walls that will stay. There must be support below where the ends of the beam rest on the walls. Hopefully this is not too confusing.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 10-18-2010, 12:36 PM   #6
Registered User
Rewards Points: 526
These walls are keeping the exterior wall from flexing in or out in a high wind or seismic area. As mentioned, contact a S.E. to see if removal is possible and any additional strengthening is needed. Positive ties to ceiling joists/rafters to walls below, additional shear panels (plywood) on other walls or ceiling joists to counter the new transmitted possible forces, etc. A visit may be needed to check the ceiling material, connections, etc. anything that would help keep the wall from moving and tape joints from cracking without the old walls. It depends on your location for most of these concerns, ask your Building department. I'd go with the doorway which you could always fill in later at house sale.
Gary
Remodeling/ Removing a wall/ Load bearing?? hybridhatchc1 Building & Construction 3 01-22-2010 11:14 AM
Removing wall in home Chasm Building & Construction 15 12-15-2009 07:33 PM
Removing a center wall DonH Building & Construction 4 05-17-2009 05:44 PM
Removing a (block) wall - questions Genhawk21 Building & Construction 3 09-08-2007 06:26 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
