I Was An Idiot When I Framed The Door Opening - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-25-2013, 08:13 PM   #16
Rewards Points: 150
I've done it ( wouldn't do it got hinged doors) but always easier than cutting doors re mortising hinges and especially hollow core doors
kaschmid3 is offline   Reply With Quote
Old 02-26-2013, 10:12 AM   #17
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
I'm not worried about the the studs being out-of-plumb. As this was originally intended to be drywall wrapped, I made certain the studs were plumb when I framed it. The rest of the house just has drywall-wrapped openings, like this:
So, that's what I was going to do here also. It was after I started hanging drywall that I decided I wanted it to look a little nicer and be trimmed with wood.
As for the casing, it fits. It's tight, but it fits. Due to some uncontrollable issues, I had to put the A/V rack about 1" further to the left than I wanted. Even if I flush the casing for the door with the stud, there is still about 3/8" to 1/2" between the two. (Excuse the frog tape and over-paint in this picture, I was in the middle of painting when I took this). White = door casing, black = a/v rack casing.
For fun, here's where the A/V rack progress is as of this morning:
hyunelan2 is offline   Reply With Quote
Old 02-26-2013, 10:23 AM   #18
AHH, SPANS!!!
Rewards Points: 1,166
if you ply the sides with the 1/4" then just set the casing to the backside of the 1/4" ply and caulk the ply to the casing. after caulked the 1/4" ply edge will not be there at all really, just a caulked edge so it should look fine... just be sure and nail plenty of nails into the 1/4" as that thickness lends to waviness in the product if not nailed correctly
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
hyunelan2 (02-26-2013)
Old 02-26-2013, 09:29 PM   #19
MikeKy55's Avatar
Rewards Points: 254
Just a DIY'r here, but I wouldn't think beyond ripping the bi-folds. Too easy.
'It's never too late to say ''THANK YOU'' to a veteran of our armed services'
MikeKy55 is offline   Reply With Quote
Wood framed metal screen door 2jakes Windows and Doors 1 11-02-2012 10:32 PM
Insulating/Finishing a Uniquely Pole Framed Room Draftsman77 Insulation 2 10-08-2012 12:16 AM
Framed basement during summer now everything is off its mark! Leoskee Building & Construction 15 02-02-2010 07:04 PM
newly framed walls getting wet mradam Building & Construction 22 01-05-2010 06:11 PM
