I Was An Idiot When I Framed The Door Opening - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-25-2013, 11:45 AM   #1
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 682
I was an idiot when I framed the door opening
Cliff's Notes: classic mistake of framing opening too small for bifold door.
It's not the end of the world, as this is only a closet in my finished basement. But the idiot who framed this project (me), didn't account for clearance space for the bi-fold door opening. The rough opening width is 73" (6'1") between the studs. Originally my thought was that I would wrap drywall around into the closet doorway (1/2" x2 = 1") and that would leave me with 72" for a 6' double bifold door. [forgetting clearance space for proper operation].
Somewhere along the line, the idea changed, and I thought it would look better with wood trimming out the doorway, instead of just drywall like the builders used in the rest of the house. 3/4" wood framing now leaves me with 71.5" rough opening for the door + needed clearance space.
Options? I see 3:
  1. Custom order a door.
  2. Get a standard 6' double door and trim 1/2" off of each panel.
  3. Frame the sides of the doorway with 1/4" boards instead of 3/4". Of course, this means I have to find 1/4" thick boards. They only need to be paint-grade, however.
Any thought as to which approach is better? Any other ideas? Drywall is up, finished, and final painted already, so cutting the opening wider is not really a viable option.
hyunelan2 is offline   Reply With Quote
Old 02-25-2013, 12:30 PM   #2
Rewards Points: 150
I would rip off Sheetrock in openings and put up your 3/4 pre primed jambs when u trim the openings u will no longer see the Sheetrock u cut out and will look much better ( and hold up better ) than Sheetrock. As this I'd s basement u t probably gonna have to cut the bottoms of the doors
kaschmid3 is offline   Reply With Quote
Old 02-25-2013, 12:32 PM   #3
Rewards Points: 528
Cut the doors, normal praise.
framer52 is offline   Reply With Quote
Old 02-25-2013, 12:36 PM   #4
Rewards Points: 150
Don't cut doors with bifold s to do it right you would have to rip equal amounts off each one if your cut is off you will see it when they r closed
Old 02-25-2013, 12:36 PM   #5
Rewards Points: 12,914
Hope you bought real wood doors not hollow core.
If your just trying to make the opening wider a simple saws all cut at the top to cut off the nails and a few taps, then add some more nails top and bottom.
Then just trim some of the drywall off.
mae-ling (02-25-2013)
Old 02-25-2013, 12:42 PM   #6
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 454
Option 4. Sliding doors?
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
The Following 2 Users Say Thank You to 123pugsy For This Useful Post:
framer52 (02-25-2013), oh'mike (02-25-2013)
Old 02-25-2013, 12:51 PM   #7
hyunelan2's Avatar
Rewards Points: 682
Door bottoms won't need to be cut, have 83" rough height.
Can't just cut the sheetrock back to widen the opening, there is a stud sitting right there.
Sliding doors were a thought, but might get inconvenient when/if I'm dragging a bicycle on a trainer (or other cumbersome object) through the door opening, versus a 6' wide opening. No doors have been purchased as of yet.
Old 02-25-2013, 12:56 PM   #8
hyunelan2's Avatar
Rewards Points: 682
Hit post before completing a thought... I think right now my leading plan is to resaw some 3/4" x 4.5" boards down to 3/8", plane them to 1/4" thickness and put them on the edges. (Of course case moulding will cover the front and back where the drywall meets the wood).
Old 02-25-2013, 01:01 PM   #9
Rewards Points: 150
Since all weight of doors will be in top use 3/4 up top and luann on the sides
Old 02-25-2013, 01:03 PM   #10
hyunelan2's Avatar
Rewards Points: 682
I thought about plywood/luann, but what about the edges of the luann? With the case moulding offset to leave a slight reveal, won't the rough edge be visible/ugly? Or should I just get around that by mounting the casing flush and not leaving any reveal? Edge band it? (can you do that with something that thin?)
Old 02-25-2013, 01:05 PM   #11
Rewards Points: 150
If u have planet or way to get 3/4 material def better off that way if not 1/4 in Mdf or Luann last resort
Old 02-25-2013, 01:06 PM   #12
Rewards Points: 150
Sorry meant planer but if u have planet those r hood to( damn stubby fingers on phone)
Old 02-25-2013, 01:06 PM   #13
Rewards Points: 150
Planer
The Following User Says Thank You to kaschmid3 For This Useful Post:
hyunelan2 (02-25-2013)
Old 02-25-2013, 07:29 PM   #14
Roofmaster
Rewards Points: 2,172
How are you going to install the casing next to the pass through. Kind of tight, no?
Old 02-25-2013, 07:55 PM   #15
Rewards Points: 616
how are you going to put 1/4 material up and keep it straight unless your studs are some how perfectly plumb
cut all 4 doors on the table saw and repaint 8 simple passes
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Wood framed metal screen door 2jakes Windows and Doors 1 11-02-2012 10:32 PM
Insulating/Finishing a Uniquely Pole Framed Room Draftsman77 Insulation 2 10-08-2012 12:16 AM
Framed basement during summer now everything is off its mark! Leoskee Building & Construction 15 02-02-2010 07:04 PM
newly framed walls getting wet mradam Building & Construction 22 01-05-2010 06:11 PM
