I Have To Notch A Floor Joist - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-31-2013, 07:46 AM   #31
I guess I killed my own thread but I think I'm going to end up with a 3" hole in the joist under the exterior wall. I will add a makeshift strongback by screwing a 2X 10 across the studs above because I'm going to put a bench there.
It is about 18" in from the exterior wall that supports it.
I'll also use long sweep 90's to make my horizontal turns.
fred54 is offline   Reply With Quote
Old 01-09-2014, 02:20 PM   #32
I ended up fabricating two 1/4" X 9" X 24" steel plates. I cut a notch out for the pipe and then throughbolted them through the joist. I forgot to take a picture but I'll do that tomorrow.
I'm thinking that should be beefy enough for a shower pan.
Old 01-15-2014, 07:52 AM   #33
I want to post a picture of the joist but I am no longer able. Did something change on the site or is it my new computer? The only image posting option I have asks for a URL.
(I have posted pictures on this thread previously.)
If I can't add a pic, let me say that I notched the joist and sandwiched it between two pieces of 1/2" plate steel and throughbolted it with 6 3/8" X 4" grade 8 bolts. Seems to be pretty sturdy.
*PICS* How do I cut fascia board notch for soffit? ConstantChange Carpentry 14 06-24-2013 08:31 AM
Notch in Girder jonmurray29 Building & Construction 16 04-18-2013 02:25 PM
Widening gap - notch sister joist or cinder block? John_W Building & Construction 6 06-29-2011 08:37 AM
Fix illegal notch in joist acerunner Carpentry 8 09-29-2010 06:01 PM
large notch in support beam kadgar Building & Construction 18 01-29-2009 10:24 PM
