I Have A Home Built In 1948 With Wood Rot By Chimney - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-22-2012, 12:15 PM   #1
I Have a home built in 1948 with wood rot by chimney
The header and sil plate are made out of six 2x4's r which are rotted behind external chimney on slope side of house. How do I repair this the right way?
no money is offline   Reply With Quote
Old 09-22-2012, 09:12 PM   #2
Rewards Points: 13,446
Not sure how a header and a sill plate come into play on the rake of a roof.
Posting some pictures would be a big help.
Old 09-22-2012, 09:23 PM   #3
Rewards Points: 6,652
Fix the roof above, along with the flashing around the chimney, is how you do it correctly. You have water intrusion on the roof surface, is why you are getting rot.
Old 09-23-2012, 09:46 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
as Gregzoll mentioned, start at the roof and work down to the framing. you will both repair the roof leak and the structural framing.
hand drive is offline   Reply With Quote
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Weeping tiles around an older home built in the 1950's and sump pumps and pits. user109616 Building & Construction 1 03-29-2011 05:12 AM
Home depot vs lowes pressure treated wood Docs911 Building & Construction 1 03-14-2011 10:30 AM
Hardwood Color in Home with stained wood trim mammaof4 Flooring 1 03-14-2011 08:23 AM
Wood stove chimney partially obstructing 1st floor window-code? Badfish740 HVAC 3 09-02-2009 08:13 AM
