Old 11-15-2012, 07:31 PM   #1
I have to glue in two remaining quartz back splashes....
and don't know what adhesive should be used.
We had a contractor install quartz in a couple of apartment units but in one unit, he could not glue down because the wall was 'bowed' out and the back splash would not lie flat against it.
We figure once we had the wall repaired, we could glue down the back splash ourselves but can't locate the tubes of adhesive he left for us. They went into a caulk gun.
Can someone tell me what to get? I have two back splashes that need to be glued down. Someone said liquid nail glue but looking at the label, it says NOT to use on marble or granite.
Help? Thank you.
sierra1194 is offline   Reply With Quote
Old 11-15-2012, 07:38 PM   #2
He should have been using thin set not mastic.
Old 11-15-2012, 08:47 PM   #3
Why not just call the guy you had install it and ask him????
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
gregzoll (11-17-2012)
Old 11-15-2012, 08:54 PM   #4
funfool's Avatar
Be surprised what 100% silicone caulk will do.
I am thinking from your post that these back splashes are in one piece pre made and just glued to the wall?
Silicone would work fine in this case, then caulk the edges for paint.
I always like some sort of mechanical pressure while it is drying for best adhesion, how you achieve that depends on situation.
If it was easy, we would not call it work!
funfool is online now   Reply With Quote
The Following User Says Thank You to funfool For This Useful Post:
oh'mike (11-17-2012)
Old 11-15-2012, 10:17 PM   #5
don't caulk the edges with the silicone tho, paint won't stick to it. use the silicone to attach them to the wall.
Old 11-15-2012, 11:18 PM   #6
be able to help me. Another customer took some time to help me out. I bought 2 tubes of Loctite silicone 3X strength in clear to glue the backsplash to the wall. And one tube of latex almond color caulk to seal the top edge.
I'm curious though, can Liquid Nails (if thats what its called be used) to glue it to the wall also? My son seems to recall the installer left that for us to use but reading the instructions on a tube at Home Depot, it says it cannot be used on granite or marble...???and why??? The counters we installed were quartz...
Old 11-16-2012, 12:01 AM   #7
funfool's Avatar
Liquid nails could work fine.
My choice would be silicone. Since I have both stocked in my van I have a choice.
For this job, I would grab the silicone, use clear painters caulk around the edges.
For painting to them.
But liquid nails would probably work. Is many brands of it for different jobs.
Is quite possible that is a brand of liquid nails for your application.
I already have silicone on my truck and know it works.
My suggestion is, If you have to go buy something, .... buy something you know works.
May find the two back splashes you install, works better then the others they installed.
But liquid nails is incredible stuff, silicone is what I would be grabbing out of the truck for the job..
Old 11-17-2012, 12:57 PM   #8
Next question is where should I apply the silicone on the back side of the two remaining back splashes? One back splash is about 8 feet long and the other is only 4 feet long.
Do I do like 3 blobs dead center spaced apart on the smaller backsplash? Do I do a beading edge all around maybe 1 inch in from the edge?
Sorry to ask these questions. They're just second nature to a professional installer but to the diy homeowner, I'm a little clueless here. Thanks
Old 11-17-2012, 01:04 PM   #9
Super Moderator
Don't use liquid nails---the oils will bleed through and spoil the granite---use silicone
Old 11-17-2012, 01:39 PM   #10
at what spots I should apply the silicone? A bead on the inside edge all around? Some blobs spaced one foot apart? ??? Thanks
Old 11-17-2012, 06:49 PM   #11
Super Moderator
I like blobs---near the top and bottom--not to big--about 10" apart--
if the wall is flat--a double bead will work well and be easier to control as far as squeeze out is concerned----
Old 11-17-2012, 07:45 PM   #12
or just the blobs on the back spaced apart and once that sets, then do a silicone or latex caulk on the bottom edge?
Old 11-17-2012, 08:17 PM   #13
Super Moderator
Yep---try not to let the silicone squeeze out and get on the wall---use a paintable caulk where the slab meets the wall---
This is a simple task----it doesn't take much to hold the splashes in place---
If you need to caulk the splash to the counter---use silicone---
counter top installers achieve a tiny bead of silicone by using this technique--
Apply the bead of silicone using a small opening---then quickly spray the caulk and counter with 'Greased Lightning' cleaner---then tool the caulk with a soapy finger--removing any excess to a paper towel.
Silicone will stick to any clean DRY surface---it will not stick to a wet soapy surface----experiment with this technique---I think you will find it useful.
Old 11-17-2012, 11:19 PM   #14
I feel confident proceeding and getting these two final pieces glued in.
The Following User Says Thank You to sierra1194 For This Useful Post:
Didn't have the 'green thing' back in our day gma2rjc Green Home Improvement 6 07-05-2012 06:23 AM
Sump pump back up DennyF Plumbing 4 02-17-2012 02:58 PM
Detached Garage Subpanel + Generator Back Feed insaneirish Electrical 3 09-06-2011 03:09 AM
Need help making a 'back band' around window/door casing. RickDel Carpentry 3 07-15-2010 04:13 PM
Severe Drainage Issue kirridam Landscaping & Lawn Care 11 07-25-2009 07:44 AM
